Home > Maintenance & Modifications > Clutch pedal assist
thomson_adam
Clutch pedal assist
Hello
I have seen a lot of the clutch pedal assist springs and was wondering if they make much of a difference on a 2.2 puma ?
Post #955387 13th Jun 2022 8:40pm
Yes they do. They can be a Censored to fit but are a very worthwhile mod, particularly if you're likely to drive in traffic a lot. Some details of fitting to mine here:
https://www.defender2.net/forum/post782396.html#782396 Darren
Post #955408 13th Jun 2022 10:52pm
Co1
For the full effect, go for the LOF clutch spring and master cylinder. The clutch is then light as a feather. Makes a huge difference and not an expensive job.
Post #955427 14th Jun 2022 8:06am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I just had the LOF pedal spring fitted to my 2.4 Puma and found it made a big difference. Everyone’s experiences differ, but in my opinion having it to light just wouldn’t feel right.
My local Land Rover specialist supplied and fitted it FOC, but I do frequent them often Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #955434 14th Jun 2022 9:30am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I have a 2.2 Puma and I don't find the clutch too heavy. However, one of previous owners may have already fitted the LOF spring. I've no idea how to check.
Post #955476 14th Jun 2022 3:24pm
htb2
Wales
Have a look at the return spring, at the top of the pedal, if it light green its a LOF one, if its not its not.
Post #955478 14th Jun 2022 3:28pm
thomson_adam
Have you done this ? Did you do it yourself ?
Post #955514 14th Jun 2022 8:37pm
Co1
I did. I think there is something about it in my build thread. Was a bit of a pig of a job as it’s fiddling and you need arms like Mr Tickle for one bit, but Luke at LOF was superb, more than happy to call me to give me some guidance on a Saturday afternoon.
https://www.defender2.net/forum/topic67542.html
Post #955541 15th Jun 2022 8:08am
Co1
Found it. It starts half way down this page: https://www.defender2.net/forum/topic67542-180.html
Post #955543 15th Jun 2022 8:15am
thomson_adam
I’ve ordered one , spoke to the chap from lof and he said get the spring first and see how you find it before changing the cylinder
Post #956044 20th Jun 2022 9:07pm
landy andy
I fitted spring (git of a job) then the slave cylinder. Too light, and too little feel for me. Swapped slave cylinder back to an OE part.
Post #956053 20th Jun 2022 9:40pm
thomson_adam
Fitted my Lof spring today
Was a right pain but got it done
I’ve had to screw in my clutch stop bolt all the way , the clutch barely feels like it’s going to come back up.
Anyone else experienced this ?
Post #956595 26th Jun 2022 5:58pm
thomson_adam
I have contacted lof and they said my pedal may need raising
Post #956601 26th Jun 2022 8:10pm
Magoyo
Argentina 2009 Defender 110 Puma 2.4 HT Corris Grey
i just bought mine, it will arrive in 2 weeks. i will comment my exp after the instalation. Hope make a big difference ¡
Post #956615 27th Jun 2022 12:13am
thomson_adam
Has anyone else had issues after fitting the spring ? Mine pauses at the bottom then returns
I hate adjusted the stop bolt at the back that didn’t make a difference , Luke suggest opening the master cylinder box and raising the pedal height. That’s made a slight difference but still not the best. I am tempted to put the original spring back In
Post #957010 1st Jul 2022 8:18pm
