Home > Puma (Tdci) > Puma 2.2 EGR |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 |
I had mine replaced but needed the MAF sensor replaced also.
Runs like a dream now 👍 |
13th Jun 2022 9:13pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1794 |
If the EGR is sticking and triggers diagnostic trouble codes it will trigger the check engine light and put vehicle in limp mode.
As you have done, clearing the codes will extinguish the Check engine light and take you out of limp mode. However, if the EGR gets stuck permanently, depending in what position it gets stuck, it can mean you can’t restart the vehicle even once you clear the codes. |
13th Jun 2022 9:36pm |
chris d3 Member Since: 06 Apr 2010 Location: sunderland Posts: 368 |
Thanks
It’s sat for 4 month while I’ve been working |
13th Jun 2022 10:11pm |
More use may free it up, there are cleaners such as Wynn’s diesel egr cleaner https://wynns2021.wpengine.com/wp-content/...ner_EN.pdf but I’m not overly keen on using these types of cleaners on a running engine.
I prefer to remove components and clean on a bench. Re changing the EGR on a 2.2, technically not difficult but the nuts bolts and studs plus pipe clips are a real challenge to get to. When I did mine on the drive it took about five hours, I think I could do it in 2.5 hours a second time. An Indy should take circa 2 hrs. A new pierburg (OEM to ford and therefor LR) EGR can be had for circa £120, so given the fitting time I put a new one in. |
13th Jun 2022 10:38pm |
