![]() | Home > Td5 > Removing clutch pedal box from Def Td5 with air conditioning |
PeteCrenshaw Member Since: 05 Aug 2021 Location: Perth Posts: 14 ![]() ![]() ![]() |
This tab also definitely needs to be removed, since it obscures the top two bolts of the pedal box.
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
Yes I did it a couple of years ago. My memory is a bit hazy on how I did it - I have a vague memory of undoing the air-con outlet unit bolts on the right hand side and bending it down a bit to give the required access. I certainly did not discharge the air con loop to do it. 2005 Td5 90 XS
1989 V8 110 CSW |
Thanks mate
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
Done it a couple of months ago without removing the AC ratchet spanner and loads of foul language.
