Home > Td5 > Removing clutch pedal box from Def Td5 with air conditioning |
PeteCrenshaw Member Since: 05 Aug 2021 Location: Perth Posts: 14 |
This tab also definitely needs to be removed, since it obscures the top two bolts of the pedal box.
13th Jun 2022 3:33pm |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 723 |
Yes I did it a couple of years ago. My memory is a bit hazy on how I did it - I have a vague memory of undoing the air-con outlet unit bolts on the right hand side and bending it down a bit to give the required access. I certainly did not discharge the air con loop to do it. 2005 Td5 90 XS
1989 V8 110 CSW |
13th Jun 2022 3:48pm |
Thanks mate I'll give that a go then! I also noticed I can get to the most obscured screw by taking out the speaker in the aircon.
13th Jun 2022 3:51pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5427 |
Done it a couple of months ago without removing the AC ratchet spanner and loads of foul language.
13th Jun 2022 9:36pm |
