![]() | Home > Maintenance & Modifications > M10 or M8 bolts for spot lamps - does it matter?? |
Honeyman Member Since: 02 May 2022 Location: Haarlemmermeer Posts: 58 ![]() ![]() ![]() |
M8 with a washer under the head will be fine: if you hit something to the extent that the m8 shears off, then there won’t be much left of the lights anyway! HTH. 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time. |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 210 ![]() ![]() |
Thank you
