Home > Maintenance & Modifications > M10 or M8 bolts for spot lamps - does it matter??
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
My new spot lamps came with large M10 bolts for fitting … should I drill out the mounting holes on my roof rack which are too small… or will M8s be fine. I am sorry if this is a dumb question but know I will get a sensible answer on here. Thanks Jerry
Post #954625 5th Jun 2022 6:08pm
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
M8 with a washer under the head will be fine: if you hit something to the extent that the m8 shears off, then there won’t be much left of the lights anyway! HTH. 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time.
Post #954627 5th Jun 2022 6:29pm
Jerry
Thank you
Post #954639 5th Jun 2022 8:02pm
