Home > Puma (Tdci) > 2.4 starting issue temp needle in max
bear100
Starting issue after service? Shocked
Today I kept to one side too service my defender, it started off pretty bad when I discovered a perishing brake pipe Rolling Eyes while under the beast but decided to carry on with the service all the same.
Oil change messy but no problem, air filter no issues, then the fuel filter.......
Removed the old filter very easily, filled the new filter with diesel and fixed in place, so now to crank the defender to draw any air through keeping the revs up..... it started for about 1 second then died, then it cranked cranked and cranked no start, again the same, the third time it started with no issues no splutter and left running for 1o mins, turned it off and tried again and it came back and didn’t fire up, starter was sounding powerful and battery has plenty of juice.
It didn’t sound like a fuel issue at all, anyway i left it for an hour and came back to it and this time it started fine first time, again an hour or so later i tried it and the issue was back but this time i noticed the coolant temperature needle went straight to max when the ignition was on Shocked and it refused to fire, the second attempt....ignition on temp needle where it should be and it fired. This happened a few times?
Has anyone had this issue? Ive checked the relays under the seat to make sure they are seated which they are 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #953197 22nd May 2022 3:45pm
kenzle8a
check the fuel cut off switch and its wiring or the relay for the fuel pump.
Post #953200 22nd May 2022 4:12pm
Greyman110
I had a similar issue to this after some work was done and I finally traced it to the CHT sensor.
I fixed it by using contact cleaner on the connections and it went away.
Post #953203 22nd May 2022 4:45pm
A 2.4 has neither of these things - no fuel cut-off switch and no electric fuel pump.
It would be worth checking that the connectors for the relays under the seat are really tight, just checking that the relays are fully home isn't enough. When you try to pull a relay out it should feel as though you're going to pull spades from the socket.
Post #953207 22nd May 2022 5:17pm
Ianh
Did you fit an aftermarket fuel filter or a genuine one ?
Has the new fuel filter been screwed fully home.
I’m just wondering if you have two issues here.
First issue is new fuel filter is not sealing, more likely to happen if aftermarket, and air is getting in fuel line.
Second issue is due to the first issue all the cranking you are having to do is highlighting a worn relay, poor contacts, or poor wiring connection which did not show before when starting at first crank.
Post #953215 22nd May 2022 5:39pm
bear100
i always use Mahle filters from the site sponsor and have done for a few years, checked and double checked the filter is home which it is, but i don't think it's a fuel issue it died to quickly on first start and after attempts there is no indication of starting just a strong sounding starter motor turning.
which relay would be the culprit? i will replace it as a matter of caution
Thumbs Up 2023 Defender L663 V8
Post #953426 24th May 2022 6:26am
The temperature gauge needle going to FSD with ignition on would not happen if this was a fuelling fault, it is an electrical fault (hence my suggestion to check and recheck those pesky relays as a fist step).
It may be that you have a fuelling issue as well of course, but it is unlikely.
There are many old threads on here discussing Puma starting issues and the temp gauge FSD symptom.
Post #953435 24th May 2022 8:11am
bear100
So strange!
I have started the defender up several times a day and the fault hasn’t returned?
I’m glad it hasn’t but I’m now in a mind jail of will it happen again Shocked because i haven’t really fixed it!
Which relay would the culprit be?......might give me piece of mind Mr. Green 2023 Defender L663 V8
Post #953595 25th May 2022 5:16pm
If it is a relay/connection issue it is likely to be either the ignition relay or the starter relay under the o/s front seat, the former being marginally more likely than the latter.
You have very similar symptoms to mine when I had a starting issue (one of several) with my 2.4. In the end I pulled out those two relays and carefully bent a slight kink into each leg, after which they were extraordinarily tight in their sockets. That particular problem has not (yet) returned.
The more interesting one was when I found that if I open the driver's electric window whilst the heater plugs are illuminated the engine won't start. Repeatable and consistent, and Landrover say quite impossible! This proved to be a PI artefact (since disabling the PI stops it from happening). I don't know if it is unique to my vehicle, I suspect it is. It will either be an earth/noise problem or an EMI problem.
Post #953597 25th May 2022 5:36pm
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
Might be of use: a few weeks ago I had a an intermittent (then permanent!) no crank issue and a bunch of random error codes thrown up. After chasing relays, ignition switch, fuses, starter & wiring for a week, it turned out to be a loom connector not seated properly in the engine compartment (see photo, lower right hand side). Contact cleaner & cable ties (to prevent a recurrence) sorted it.
 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time.
Post #953603 25th May 2022 6:34pm
