Home > General & Technical (L663) > Car isn't reminding me of a service
dizeeduckie
Just realised I've had my Defender for well over a year so it's probably needing a service?
The car has never mentioned it to me. I went into the Settings menu today and it says:
"Next service due not available"
"Next oil change due not available"
Why is it not available?! And should my car have a service after the first 12 months? Every other car I've owned has needed that.
Post #952663 16th May 2022 9:28am
Farmerben
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Think it's every 2 years now on new Land Rovers https://instagram.com/bentheoandrews
Post #952668 16th May 2022 10:24am
X4SKP
Hello dizeeduckie...Relax Cool
"Next oil change due not available''
Wrong Terminology IMO... 'not due' or ideally show 'mileage / months' until due Mr. Green
You could, as many do, reduce this...oil + parts inexpensive compared to engine problems.
Good Luck... SKIP
Post #952670 16th May 2022 10:33am
Tim in Scotland
It should tell you when it’s due in the app too, along with range to run on the Adblu contents if it’s a diesel
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #952681 16th May 2022 12:11pm
peanutbob
It could do with a low battery key fob warning as well! My August 2021 wouldn’t start this morning either with the fob I always use and the spare which has never been used. LRA arrived and replaced both batteries …all ok thereafter.
Apparently they need over 3 volts to work, and because the fobs are continually live sending out rolling codes, the batteries need replacing regularly…even as low as 3 months. I seem to remember that BMWs send out a warning when the fob batteries are low.
Post #952708 16th May 2022 6:28pm
Tim in Scotland
Next service due etc info in Pivi Pro will show if you drive the car off for a couple of miles in my experience. It won’t display if you just start it up on the drive - I suspect it has to do with the oil quality sensor that measures any oil dilution from incomplete DPF regens Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #952709 16th May 2022 6:36pm
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
I have enough with the wife telling me what to do, if the car does the same it’s got to go…!!. Whistle Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #952726 16th May 2022 8:46pm
lightning
When you find the cost of a service, you'll be glad it's not due for 2 years.
Post #952762 17th May 2022 1:15pm
zilch
Australia
After hearing about all the dpf regen and oil dilution issues on the mid range JLR
products that have contributed to engine failures, I have decided to ignore LR and
stuck with 6 monthly /12k km oil + filter change and a full annual service.. I plan to keep
mine far longer than one on a standard lease contract yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #952833 18th May 2022 7:20am
lightning
Won't do it any harm, and probably a good idea.
Post #952838 18th May 2022 8:10am
mse
Or of interest how much is a first service at a main dealer now? Mike
Post #952923 18th May 2022 11:06pm
Buz1500
I’ve been quoted £450.
P300 SE
Post #952925 18th May 2022 11:30pm
Buz1500
P300 SE
Post #952926 18th May 2022 11:32pm
