![]() | Home > Maintenance & Modifications > Security Measures |
| jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408
The first thing I would be doing is deleting the post listing what security you currently have - never post what you have as it only helps them come more prepared.
The more layers of security you have, the better, but obviously there gets to a point when you have so much security it becomes such a pain you never use it. |
| apegeneral Member Since: 06 May 2022 Location: Sheffield Posts: 3
Hi Jimbo
Thanks for the heads up! I did think it could get very tedious.... Cheers |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
There are many threads on security on this site and a search will find lots of useful material. In my own built thread, linked below, there's details of some of the more straightforward measures that I've applied. Darren
Hi Darren,
That's great thanks for the advice its very much appreciated. Cheers! |
| The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303
The rule I was told was for every active defence type add a passive type :
steering wheel guard/lock - datatag/etching peddle lock - tracker/airtag gearbox lock - smartwater/microdots Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 612
The Optimil removable steering and lock gets my vote.
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello apegeneral and welcome.
As advised use the search function... your question has been asked multiple times and there is lots of advice on this subject...
Try to prevent 1st recover 2nd, Many 'specialist' car owners spend around 10% of the Vehicles Value on Security. Good Luck* *what you don't want to rely on... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
| jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403
Remember, if it takes too long to set all the devices, you’ll end up not bothering.
Oh, by the way someone will soon come along and say the extremely irritating “ if they really want it , they’ll get it whatever you do!”😡 Of course this is just nonsense. A couple of visible, and a couple of invisible deterrents should be enough. 2002 td5 90 county hardtop |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2706
Maximum Security……
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11096
Can't beat a bit of Blackadder
| All times are GMT |
