Home > Puma (Tdci) > Brake Servo Oddball
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Brake Servo Oddball
My 2011 Puma doesn’t appear to be giving me any brake servo assistance. Doing the usual servo test of pump and hold brake pedal then starting it makes no difference to the pedal.
If I remove the servo vacuum pipe I have a good vacuum suck at the servo pump and removing it from the servo also a good release of vacuumed air. I was expecting one or the other to show a fault.
Anyone experienced this or offer any other rational?
Thanks
Rob Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #952334 12th May 2022 4:34am
LR90XS2011
not sure this is an issue I have a 2011 if you can wait until this evening I will see how mine behaves, is yours ABS / TC fitted? DEFENDER 90 TDCI XS,
Post #952335 12th May 2022 6:36am
Leamreject
Thank you, if ABS isn’t standard on the 2011 Puma HT then my model doesn’t have it which means it won’t have TCS either. Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #952351 12th May 2022 10:09am
LR90XS2011
probably not representative then as mine has it DEFENDER 90 TDCI XS,
Post #952384 12th May 2022 5:41pm
Linds Hanson
Check for fatigue cracks around where the master cyl fits onto the servo particularly around the engine side. These can close up when the pedal isnt depressed allowing vacumn build up but then open up when the pedal is pressed allowing air into the servo housing. Also check the o ring seal on the end of the master cylinder to servo joint.
Post #952386 12th May 2022 6:03pm
Leamreject
Thanks I will take a look Thumbs Up Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #952412 12th May 2022 9:07pm
