|  | Home > Puma (Tdci) > Brake Servo Oddball |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3682      | not sure this is an issue I have a 2011 if you can wait until this evening I will see how mine behaves, is yours ABS / TC fitted? DEFENDER 90 TDCI XS,
 I hope everyone is well and your land rovers make you happy | ||
|  12th May 2022 5:36am |
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970      | Thank you, if ABS isn’t standard on the 2011 Puma HT then my model doesn’t have it which means it won’t have TCS either. Ride like you stole it!!
 If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT | ||
|  12th May 2022 9:09am |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3682      | probably not representative then as mine has it DEFENDER 90 TDCI XS,
|  12th May 2022 4:41pm |
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 540    | Check for fatigue cracks around where the master cyl fits onto the servo particularly around the engine side. These can close up when the pedal isnt depressed allowing vacumn build up but then open up when the pedal is pressed allowing air into the servo housing. Also check the o ring seal on the end of the master cylinder to servo joint. | ||
|  12th May 2022 5:03pm |
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970      | Thanks I will take a look   Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT | ||
|  12th May 2022 8:07pm |
| Posting Rules
