Home > Td5 > TD5 1999 - Starting problems / immobilizer |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 576 |
Look into engine ECU with Nanocom - it should tell you, if this ECU is imobilized or not.
When 10AS is imobilized, it is blocking the stater relay, if engine ECU is imobilized, it is blocking injectors controll. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo |
12th May 2022 9:25am |
Norwegian_mads Member Since: 11 Aug 2021 Location: Oslo Posts: 2 |
Thanks MadTom!
Yeah, the AS10 is demobilized, but still no crank. So ill probaly need to look into the starter relay. But ECU let it self be de-mobilized for some reason. |
12th May 2022 9:34am |
