![]() | Home > Maintenance & Modifications > Possible to remove dents from exhaust? |
SRJCOX1 Member Since: 08 May 2022 Location: W. Sussex Posts: 2 ![]() ![]() ![]() |
A couple of photos - one dent in the front section behind cat, the other in the middle behind the silencer.
![]() Click image to enlarge ![]() Click image to enlarge |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
I would consider replacing, I know it’s not cheap but at least then will be done long term.
As it is, I’d say you won’t get much more life out of it if you tried a repair, and I would have thought it’d need to be tack welded and pulled and in the process you will get a rust spot and in next to no time you’ll end up with a hole in it. You maybe able to use a sleeved straight section, if you go for a cat back system for now. As usual obviously a compete replacement is best but costly. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17989 ![]() ![]() ![]() |
The dents are not worth bothering about since they won't affect the operation of the vehicle. The state of the flange on the rear pipe suggests you'll be needing a new exhaust soon anyway, although if you're lucky the front section (with DPF/Cat) won't need replacing. The dent on the cross-pipe won't be an issue.
There appears to be a lot of rust and plenty of oil leakage on the vehicle, and I would be more concerned about this than some minor dings on the exhaust. |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3782 ![]() ![]() ![]() |
I would imagine repair would cost more than replacement. I’ve got straight through pipes on my puma and there is no noise difference in the cab, the DPF does all the necessary muffling.
