Home > Technical > Heated seat connections on XS seat
Page 1 of 3 123>
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
Ok my first question, I'm sure you'll all be sick of me by the end of the month!!!!
I have a 110 DC which was a limited edition I believe. That mean't it came with XS seats (Half leather)
I was having a look around getting familiar with everything when I noticed that the seats have wiring coming out from the back rest & a connector under the seat!
Now with it being a land rover I won't make any assumptions!! but I imagine they are for heated seats.
How would I figure out if it's just the wring or the actual elements are present too?
Post #95158 20th Oct 2011 9:40am
Hi, yes the heater pads are present in the seats, the wiring will be under a grommet at the side of the seats....
If not it will need wiring in, we've wired quite a few in now Cool QRZ 2e0vpf
Post #95159 20th Oct 2011 9:43am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
Put 12 volts across it and see if you get a hot arse? Laughing
(hopefully someone who can actually help will be along in a minute)
Post #95160 20th Oct 2011 9:43am
airpusher
Thanks Greeni
I just had a look, I can see two rubber grommets at the drivers door side but looking in the compartment under it there are no spare connectors or wires!!
But I assume the expensive bit is the seats & heating elements so I could get the switches & wire the connection in or as you say get someone like yourselves who know what your doing to do it!!!
Twopoint.....I did have that though before slapping myself
Post #95162 20th Oct 2011 9:54am
TJ101
So guessing you have no switch on the dash ??? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #95169 20th Oct 2011 10:29am
airpusher
HI TJ
No I don't have the switches just the blanks. It looks like I have the seats but nothing else.
I've just been looking at switches from Dingocroft but I'm getting more confused over what I actually need with connectors etc!!
Post #95170 20th Oct 2011 10:31am
MMmm yeah, no wiring !
We use (and can supply) Durite modular momentary switches, with illuminated heated seat lenses in the switch and wire them with a ten minute relay.
Here's a (crap) picture, just taken off my phone, of ours in the F8
 QRZ 2e0vpf
Post #95171 20th Oct 2011 10:33am
Just better say, the switches pictured are not final... The top half of the switch will be black, and not green with marker pen on Rolling with laughter We stole the proper ones off for a customer....Customers come first ! QRZ 2e0vpf
Post #95172 20th Oct 2011 10:36am
TJ101
Without robbing Greeni of a sale,, I would also check what the price is of genuine switches ??
Keeps it "factory" looking California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #95174 20th Oct 2011 10:42am
TJ..I had factory switches for my TD5...they are still in my toolbox, a pain to wire up because the factory didn't leave me the seat loom in either Crying or Very sad I use the standard waeco switches in mine... 2 heat settings Cool QRZ 2e0vpf
Post #95175 20th Oct 2011 10:45am
airpusher
Thanks Greeni
Firstly what is an F8 (Sorry if it's a silly question)
I was hoping to use the blank spaces already present on the dash to keep it looking original.
I found the tread on here about the switches, but it seems the TD5 has a left & right but to what I can fathom they are identical bar the connector fitting on the back.
So I was thinking two of these YUG102430 switches and alter the connector to make it fit.
I think reading it's the connector from the under the seats to the wiring loom thats hard to find!
Edit.....I type so slow, you all beat me to it!!!
Post #95177 20th Oct 2011 10:53am
F8 is this..
You can use genuine switches, I'm very impatient for my own 90, I just wanted the quick route Mr. Green
What spec is your 110??
And curiously, where was it from? QRZ 2e0vpf
Post #95179 20th Oct 2011 11:00am
airpusher
ooooh now that looks like fun!
If only I had a larger budget!!
I may well regret trying to keep it looking original! We'll see how it all goes! I think the hardest part will be getting the wiring in place & making the connection to the seat.
I believe it the silver limited edition, They also did a black one I think. To what I have dug up, its limitedness is down to the Zambezi silver & some of the extras.
I think it's country spec with some XS upgrades, ie seats, A/C central locking but I have no idea whats standard.
By were from do you mean were I bought it?
Post #95180 20th Oct 2011 11:14am
It seems strange that people spec XS seats and they aren't wired up by the supplier ? QRZ 2e0vpf
Post #95209 20th Oct 2011 2:06pm
airpusher
I don't think they were spec'd by the person who bought it.
The edition that it is says it has half leather seats but there is no mention of heated or option to add. The A/C was an option looking at the brochure for the edition I found.
So I think it was maybe land rover throwing in the XS seats but on a lower spec body!
I did have an image of the spec sheet but it keeps failing to upload.
So I had a look at the wiring diagram and can see the easy bit, seats direct to each switch (forgetting about the connectors for now) then I need to wire the switch to "fuse box satellite" (No idea which one that is) & the from the 20Amp fuse to the "Ignition relay" (again no idea which relay is the ignition one.
MMMMMM
Post #95217 20th Oct 2011 3:22pm
Page 1 of 3 123>
