![]() | Home > Maintenance & Modifications > Added Boost and EGT Gauges |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 697 ![]() ![]() ![]() |
Looks good but would have thought plugging in an Ultragauge would have been a lot easier?
Gives boost and temperature at Cat which is close enough to EGR. ![]() Click image to enlarge |
big110 Member Since: 02 Nov 2016 Location: Pinner Posts: 395 ![]() ![]() ![]() |
That would have been a good
Option too. Looks to do more as well. I’d ultimately like to go with a Madman but I really dig the analog gauges. Great set up you have! |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167 ![]() ![]() ![]() |
Temperature at Cat must be a 2.2 thing? There's no temperature sensor around there on a 2.4, is there? |
Nice job, by the way, big110. I don't think you can have too many gauges. And I'm definitely with you on analogue. I use Torque Pro on an old Android phone, but it's not the same.
Maybe it’s the DPF probe that’s picking up the temp? |
Looking at the 2012 wiring diagram/workshop manual (which I should have done first) the 2.2 has a three EGT sensors: post DPF, pre-catalytic, post-catalytic. Lots of choice.
