Home > In Car Electronics > Noco GBX45 + TMax compressor & shared Anderson plug
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
Hi all,
I need some guidance in electricity as I am a rookie in the domain. So pardon me if I am asking stupid questions.
What I have:
- a NOCO GBX45 jump start pack. Out of the box it comes with a 20cm long 8AWG cable (10mm2) with alligator battery clips.
- a NOCO GBC007 47cm adapter extension cable, still 8AWG cable, compatible with the GBX45 to jump start.
- a TMax 160 air compressor. It has a connection cable about 220cm and also about 8AWG with alligator battery clips. TMax draws 45A.
What I would like:
- to fit an Anderson plug to the NOCO extension instead of the eyelet M6 terminal connector, as well as to the TMax cable (and keeps the alligator battery clips as alternative)
- to have a single Anderson socket out of the battery box to either jump start with the NOCO or use the compressor.
What I am absolutely not sure about is whether or not it is feasible, which Anderson socket, cable gage and connector to consider:
- SB50 with 6AWG or 8AWG connectors/cable
- As advised here in other threads, use Anderson SB175 with 2AWG (35mm2) for jump starting
- Do nothing and keep removing the seat to access battery box in the rare case I would need to access the battery terminal Smile
Thank you in advance for your info and advices on what/how doing it
Greetings Lolo
Post #950548 25th Apr 2022 9:56pm
DSC-off
Hi, have you considered fitting remote battery terminals to the front of the front of the seatbox?
The compressor, charger or jump leads can be clipped to these without removing the seat and no need to fit Anderson plugs to everything.
https://www.ebay.co.uk/itm/333640157610?ch...gKT9vD_BwE
Post #950552 25th Apr 2022 10:54pm
lolo
Hi DSC-off! Thank you for your info and link.
No, not really so far. I am not sure I am very confident in having those external battery terminals around... Most probably no rational on this, but electricity, me and water ingress seems to be a perfect combination for fireworks Laughing Not sure neither that the Swiss MOT will like it much...
Post #950556 25th Apr 2022 11:20pm
DSC-off
Anderson plugs aren't waterproof either. Wink
Post #950559 25th Apr 2022 11:39pm
