![]() | Home > Technical > Puma rear seats part |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1068 ![]() ![]() ![]() |
the thing marked 16 is just a nylon strap. Easy enough to make your own.
If you're missing the other bit, you need to go shopping - that's what locks the seat down and provides support. |
Anvil Member Since: 16 Jan 2009 Location: Milan Posts: 21 ![]() ![]() ![]() |
.. and in fact, it holds all the weight ![]() |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 549 ![]() ![]() ![]() |
Hi Guys,
sorry I might have explained it wrong, i have the seat base support, its the clip i need to hold it in the folded up position, i have the strap also just missing the clip part ![]() ![]() ![]() |
jpboost Member Since: 13 Apr 2021 Location: Gatwick Posts: 378 ![]() ![]() ![]() |
I believe the part you need is LR062679
This should be a 2 piece kit consisting of a plug/collar and a firtree that goes into it. You need to order 1 for each side. I've had a couple on order for a while with one of the main parts suppliers, but understand that they are currently on backorder with LR so have not got them yet. I've not chased mine lately, so please do let me know if you manage to get some! a word of warning, at one point LR sent out packets marked up with the correct partno Lr062679, but they simply contained a single standard pop-rivet! clearly someone at LR having an off day! EDIT: this message prompted me to chase up my order. Apparently they're now on backorder on LR with no ETA. I may resort to plan B which was to set a nutsert into the frame and use a bolt. This will work fine, but I think (unless you have a right angle drill) that I'll need to take the frame out of the car to expand the hole to be the right size for the nutsert. Thanks Jon Last edited by jpboost on 25th Apr 2022 10:50am. Edited 1 time in total |
Ah brilliant thanks Jon,
I see LR Parts are stating they have them in stock, will order from there I think, ugh have that happen a few times where i got the wrong part in the correct marked bag ![]() Shane |
no, lrparts is who my order was with and just called me to say they're effectively NLA.
the service from them has been great, but clearly if LR don't have any, there's not a lot they can do. |
Ah crap, thats all we need
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
John Craddock have them..
https://www.lrworkshop.com/diagrams/land-r...rame_45088 https://www.lrworkshop.com/parts/HYC500090 if not this is a good source of fixings https://www.vehicleclips.co.uk/screw-fit-p...d-1007932/ |
Lodelaner Member Since: 04 Feb 2010 Location: Lambourn Posts: 635 ![]() ![]() ![]() |
Worth checking the parts you have, the fir trees were in the parts box I sent. I pulled the straps out to separate the frames from the seats when packaging up.
You can clearly see how they connect in the photo from my ad. ![]() Click image to enlarge https://www.defender2.net/forum/topic80140.html JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
Perfect thanks Jonathan, sorry, it was in no way a dig at you. I read they break easy and assumed that's what happened,
I've 2 bolts i'm not sure where they go, can i send you a PM of the pics and see can you remember Shane |
It’s all good, just thought it would be worth mentioning in case you ended up ordering something you already have!
By all means send pics. I wonder if the spares might be seatbelt mounting bolts ? JB @Lodelaner Instagram Youtube greenlaning and other LR related content |
