![]() | Home > Technical > Topless Defender with half-door |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello Arthur Mac
This sort of thing... ![]() ![]() Click image to enlarge https://arrowworks.co.uk/land-rover-defender-90-soft-top-55/ SKIP https://www.defender2.net/forum/topic83242.html |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 879 ![]() ![]() ![]() |
Maybe add some kind of roll protection to that. I use the military hoop on mine for protection and to provide mounts for the seatbelts. It isn't fastened back to the chassis but is better than nothing and likely to be sufficient for the slow speed topple I am likely to suffer.
Here it is 2 weeks ago at a trialing event. ![]() Click image to enlarge |
Also, I fitted the military 90/110 two part doors but these are effectively the same as the series doors.
You will need the correct door locks and catch plates and also need to modify the door check straps. I managed to graft in the check strap gubbins from my rotten Defender doors. |
If you go the direction of having a roll bar then Safety Devices do a whole host of hoops and cages for a 90 soft top http://www.safetydevices.com/expedition/pr...mp;cageno= |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
This kit may be of interest: https://www.sp-4x4.com/DEFENDER_SERIES_DOO...wp7103.htm |
west4x4 Member Since: 23 Jan 2010 Location: Rutland Posts: 144 ![]() ![]() |
Seen reports of the SP doors not fitting as have been made slightly oversized. Ifhou buy some measure them before fitting
