![]() | Home > Puma (Tdci) > Oil leak hunting |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
Pic 1:
Diff Pinion oil seal, in my opinion that can be caused by a failed / failing Prop Shaft UJ. So if you get this one repaired make sure the UJ’s are checked in particular the UJ nearest the leak on the diff nose. I had this seal replaced once, and it leaked again not long after. In the end I had to get it replaced yet again but I found it was the Prop UJ had a bearing failed on it. And you could only tell by taking the prop off it was very difficult to tell in situ. Pic 2 & 3: Difficult to tell due to picture but cleaning the sump would be a good start as it maybe the seal going on it, if the seal is replaced the sump needs replacing itself really. It could be leaking from further up or the oil filter. Is the oil filter a genuine one? Anyone else have any views? Pic 4: Possibly the steering box, this one doesn’t look too bad should be able to be cleaned up and keep an eye on. To clean up use some brake cleaner, an aerosol one is ideal like holts. If you are going for a service and oil change, then that’s an ideal time to change out the sump and seal in the process, as this is what I had done and makes sense as the oil will need to be changed anyway so is an ideal oppertunity. Again the same with the diff pinion oil seals, you may as well get the diff oils changed. Looking at the prop UJ’s I would suggest getting the UJ’s greased and also the sliders if the nipple is present. Hope that helps, most of us have had the same leaks on our own. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3765 ![]() ![]() ![]() |
As Steve mentions, start with a good de-grease and clean in order to spot the tell tales easier.
TXH90 Member Since: 19 Jul 2020 Location: Worcs. Posts: 54 ![]() ![]() ![]() |
Thanks both, esp Steve for the detailed analysis
![]() Ta very much Tom |
I believe the latest sump is also reworked from the original if an early Puma like mine is and yours by the look of your profile.
Perhaps someone can explain why, I can’t remember why but there was a clearance issue if I remember under articulation or something along those lines. I had my sump replaced a couple of years ago for the same reason of leaking seal and was getting aged. On mine I then sprayed it with a thin spray of black dinitrol, as they can suffer from corrosion. If you do, leave it at least a day after to evaporate off and cure as it gets hot. It’s kept my old one and the new one in really good condition. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Yes mine is an early 2.4 Puma TDCi 07 plate. Seems I bought just as some key bits were giving up the ghost which is understandable for a then 13 year old vehicle. I watched a pretty comprehensive video on replacing sump by Life Projects on YT ( allbeit the engine out of the bay) and hopefully am building confidence to do it. If not as someone else has said you can always call out the mechanic for them to sort when you fluff the job up
Just reaslised I already follow you on IG Colin; I have a similar 90 County HT (cairns blue?!) though nowhere near as clean set up. Nice work! |
Loire Blue
Thanks Mate. Stick a pic up here so we can have a look!
Gladly- now got a roof tent on it for trips and a few more scuffs and scrapes from said trips
![]() ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Forgive the gormless look in first photo- I’d just bought it hence the elation
