![]() | Home > Technical > Tachograph removal |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Due to location I’d recommend having a chat with Devon 4x4, they’ll be very knowledgable with such things.
That would be my suggestion. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| 3disco Member Since: 21 Mar 2022 Location: Devon Posts: 5
Thankyou for your suggestion.
Many thanks for your PM Steve I will call them tomorrow (I needed to make three posts before I could PM you back) done now!
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
As I recall the tacho input has by law to be connected to the speed transducer on the LT230, displacing the speedo connector. It may be as simple as unplugging the tacho (which should have a tamper-proof seal) and plugging the speedo back in.
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2243
Instructions for fitting one are here:
http://vdotachograph.co.uk/land-rover-defe...nual-2008/ As they say, removal is the reverse of installation Steve 02' 110 TD5 Double Cab Rebuild Thread |
Many thanks for all your replies.
That's a useful link, thanks for posting.
Tachograph and wiring removed today took about 2.5 hours removed all the wires that had been spliced into the loom/cigar lighter /speedo and some that were spliced into wires that I did not know were they went it was all a bit messy but has been tidied up now,a new transducer was fitted into the gearbox and the original wiring was found tucked away but not water/dust proofed so connectors were a bit corroded but all cleaned and working now,thankyou for all your help.
