Home > Technical > Tachograph removal
3disco
Tachograph removal
Hi new here but been on the disco3 and evoque forum for many years can anybody help please my friend has a 2011 110 defender which is fitted with a Siemens dtco 1381 Tachograph that he wants to remove and put back to standard what would require replacement and what wires would need altering to get the speedo working again,many thanks in advance for any response’s.
Post #946509 21st Mar 2022 7:27pm
Due to location I’d recommend having a chat with Devon 4x4, they’ll be very knowledgable with such things.
That would be my suggestion. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #946511 21st Mar 2022 8:28pm
3disco
Thankyou for your suggestion. Very Happy
Post #946516 21st Mar 2022 8:50pm
3disco
Many thanks for your PM Steve I will call them tomorrow (I needed to make three posts before I could PM you back) done now! Very Happy
Post #946525 21st Mar 2022 10:25pm
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #946526 21st Mar 2022 10:37pm
As I recall the tacho input has by law to be connected to the speed transducer on the LT230, displacing the speedo connector. It may be as simple as unplugging the tacho (which should have a tamper-proof seal) and plugging the speedo back in.
Post #946541 21st Mar 2022 11:46pm
rallysteve
Instructions for fitting one are here:
http://vdotachograph.co.uk/land-rover-defe...nual-2008/
As they say, removal is the reverse of installation Thumbs Up
Post #946557 22nd Mar 2022 9:13am
3disco
Many thanks for all your replies. Very Happy
Post #946578 22nd Mar 2022 12:24pm
That's a useful link, thanks for posting. Thumbs Up
Post #946580 22nd Mar 2022 12:35pm
3disco
Tachograph and wiring removed today took about 2.5 hours removed all the wires that had been spliced into the loom/cigar lighter /speedo and some that were spliced into wires that I did not know were they went it was all a bit messy but has been tidied up now,a new transducer was fitted into the gearbox and the original wiring was found tucked away but not water/dust proofed so connectors were a bit corroded but all cleaned and working now,thankyou for all your help. Very Happy
Post #947139 26th Mar 2022 9:09pm
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #947181 27th Mar 2022 1:41pm
