![]() | Home > For Sale & Wanted > [Wanted] Factory electric window parts |
| cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308
Post removed. Richard
Either a 90, 110 or 130. Discovery 5 |
| rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242
The inner door panels on all doors 02> are compatible with the electric window motors/mechanisms if that helps.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
| Gasket Member Since: 30 May 2020 Location: Manchester Posts: 629 |
It does help Steve, thank you.
Saves me popping off the door cards to have a look. At least I know it’s only the commonly available bits I need to track down. |
| Callum45 Member Since: 01 Jan 2018 Location: Liverpool Posts: 109
I dont know how set you are with using genuine parts but Masai do a electric window conversion kit for around £200.
It has everything you need to retrofit electric windows. |
| freddie206 Member Since: 18 Oct 2015 Location: Skipton Posts: 90
I’ve just done exactly what you’re looking to do. I used all genuine parts/looms except for the window regulators which I sourced from BoltonBits and so far have worked a treat. They use the same connector on the motor as the genuine door loom.
Thanks all - I'm now sorted for parts.
