Home > For Sale & Wanted > [Wanted] Factory electric window parts
Gasket
I’m looking to add genuine parts electric windows to my Puma.
If anyone has a pair of regulators/motors available (or any other parts required for the job), just let me know.
I’ve already gathered all the central locking parts, I have an advert out for some door looms, but may as well do the windows while I’m at it.
I’ll probably also need switches and (not sure about this one) possibly the inner door panel - I can’t work out if the inner door panel (BDO710030, BDO710020) is a part fitted to all puma doors or if it is EW specific.
Thanks.
Post #945510 12th Mar 2022 11:17am
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Post removed. Richard
Either a 90, 110 or 130.
Discovery 5
Post #945629 13th Mar 2022 2:28pm
rallysteve
The inner door panels on all doors 02> are compatible with the electric window motors/mechanisms if that helps.
Post #945647 13th Mar 2022 4:11pm
Gasket
It does help Steve, thank you.
Saves me popping off the door cards to have a look.
At least I know it’s only the commonly available bits I need to track down.
Post #945707 13th Mar 2022 11:02pm
Callum45
United Kingdom 2003 Defender 90 Td5 SW Epsom Green
I dont know how set you are with using genuine parts but Masai do a electric window conversion kit for around £200.
It has everything you need to retrofit electric windows.
Post #945713 14th Mar 2022 8:34am
freddie206
United Kingdom 2006 Defender 110 Td5 HT Belize Green
I’ve just done exactly what you’re looking to do. I used all genuine parts/looms except for the window regulators which I sourced from BoltonBits and so far have worked a treat. They use the same connector on the motor as the genuine door loom.
Post #945714 14th Mar 2022 9:12am
Gasket
Thanks all - I'm now sorted for parts.
Post #945893 15th Mar 2022 9:14pm
