Home > In Car Electronics > Puma totally dead!
Greyman110
Puma totally dead!
Had no issues and everything been working as it should.
Haven’t driven it for about a week. Went to unlock today and central locking didn’t work. Once I was in, turned the key and nothing. Connected to noco 150 and nothing. Connected to cteck and the dash started clicking.
Please see video. https://filebin.net/hsl7gbntsen5jkit
Any insight to this would be grateful appreciated!
Post #945522 12th Mar 2022 12:47pm
gcc130
Is the battery in the key fob ok?
Post #945523 12th Mar 2022 12:50pm
Greyman110
Yes, replaced the batteries last year and went through the procedure for the change.
The car battery is also new last year.
Everything was dead...like if you remove the battery from the car!
I even looked to see if someone has tried to break in but don't thing thats happened.
Post #945524 12th Mar 2022 1:13pm
nitram17
Have you checked that no one has cut the battery cable under the truck?
Checked the earth connection?
Post #945527 12th Mar 2022 2:21pm
Check battery clamps aren’t loose and battery voltage. That clicking is relays and usually is a sign of loose battery clamps or main power or ground supply ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #945530 12th Mar 2022 2:26pm
Greyman110
Thanks. I'll get properly under the car and have a look.
Post #945540 12th Mar 2022 3:34pm
Screbble
I agree with Steve - check clamps/earths
Post #945548 12th Mar 2022 5:55pm
ozy013
Australia 2010 Defender 110 Puma 2.4 SW Rimini Red
I had this same issue last Christmas. It turned out to be the key fob battery. When I service the car every year I always change the fob battery. It had only been changed 3 months prior. The car had sat for a week or so during the Christmas break. I checked everything else, not thinking it would be the fob battery. However after an hour or so of head scratching, checking connections and fuses, I changed the fob battery and hey presto, central locking worked and she fired right up.
Hope this helps.
Post #945614 13th Mar 2022 12:10pm
discomog
Similar experience to Ozy013, had a problem with key fob the other week, despite changing the battery last September it only lasted 5 months, so worth checking. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #945619 13th Mar 2022 12:23pm
Greyman110
Thank you for all the pointers.
I reconditioned the battery and fired it up and all was normal...I did notice that the lights were on when I did a walk-around! It was at this point a neighbour came over and asked if i had a battery problem. He then told me he saw my side lights on one night but I wasn't around when he tried to tell me.
So seems like I've had a moment!! Embarassed Rolling with laughter
Post #945672 13th Mar 2022 6:59pm
bear100
Rolling with laughter Rolling with laughter 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #945687 13th Mar 2022 8:31pm
Ianh
Welcome to the senility club Greyman... I’ve been a member for several years.
Post #945702 13th Mar 2022 10:09pm
