Home > Technical > Will earlier Defender wheels fit the Puma Defender?
mermoto
Done a search but can't find a definite answer - will earlier Defender wheels fit a 2008 Puma Defender? What is the maximum tyre size that will not rub with standard suspension Question
Thanks
Mermoto Smile
Post #94504 16th Oct 2011 3:06pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Yes they will fit. Thumbs Up
I run 285's on 8.5 inch wheels without any problems.
Boy
Post #94505 16th Oct 2011 3:18pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Like he said Smile
All defender wheels will fit all Defender models, past and present Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #94507 16th Oct 2011 3:24pm
leeds
We run 255/85/16 tyres on standard suspension and on a 2" lift on our 110's. These tyres have a 33" diameter. No problems with a 33" diameter tyres on standard suspension.
Adjust your front steering stops so that the front wheels just touch the front radius arms for best turning circle.
Brendan
Post #94509 16th Oct 2011 3:32pm
mermoto
Cheers guys for the quick replies - what a top forum this is Thumbs Up
Mermoto
Post #94527 16th Oct 2011 5:28pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
Keep in mind that not everything fits perfectly out of the box. I just installed a set of ANR 1534 HD steel wheels ("old" d130/NAS 110 style) on my 09 Puma and I had to grind a few mms off the outside edge of the rear brake calipers for clearance.
Post #94727 17th Oct 2011 5:43pm
MartinK
I thought there were certain restrictions? Some 90's have a lower load rating that 110/130 models?
There was a thread warning that some wheels are lower-rated for weight than others...
See LandRoverAnorak's reply to this thread:
Quote:
Freestyles (and the earlier 200 series alloys - Castor?) are not rated for a 110. ISTR they're only rated at 850kg, whereas Boosts are 1100kg. Freestyles were only ever offered on 90's for this reason.
http://www.defender2.net/forum/topic8203.html?highlight= Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #95010 19th Oct 2011 8:54am
JSG
Very true - however IIRC Mermoto has a 90 so should be ok. What Martin says is correct - although the studs and PCD is the same meaning the wheels will fit you need to bear in mind that not all the wheels are rated for a 110 or 130. John
2011 Tdci 110 CSW XS
Post #95039 19th Oct 2011 1:01pm
Dave-H
And ... he did state 'Defender' wheels.
All will fit all ... earlier models were not actually 'Defenders', but Landrover 90. 110 etc Razz Guns and Landrovers .... anything else is irrelevant.
Post #95098 19th Oct 2011 8:06pm
They've been Defenders since 1991 but some wheels fitted since then are still not rated for the larger models - Freestyle ones in particular. If the OP has a 90 then it's not specifically an issue, but as a general statement, I'm afriad all won't fit all. Darren
Post #95105 19th Oct 2011 8:57pm
Change fit for suitable Thumbs Up
Post #95116 19th Oct 2011 9:33pm
Yeah, of course. I was paraphrasing, but the reality is that whilst they'll all physically fit on the hubs, some just aren't suitable for some models. Darren
Post #95121 19th Oct 2011 10:00pm
Dave-H
LOL ... but he didnt ask if they are/were 'suitable', only 'will they fit'?
So yes, all will fit all Razz Guns and Landrovers .... anything else is irrelevant.
Post #95187 20th Oct 2011 11:50am
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
A treestump with 5 holes drilled in will "fit" a Land Rover hub.... doesnae mean it'd make a good wheel though Rolling Eyes
Post #95194 20th Oct 2011 12:47pm
Lorryman100
I dunno............ served Fred Flintstones needs well enough. Very Happy Whistle
Post #95198 20th Oct 2011 12:59pm
