![]() | Home > Technical > Will earlier Defender wheels fit the Puma Defender? |
Yes they will fit.
![]() I run 285's on 8.5 inch wheels without any problems. Boy |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Like he said
![]() All defender wheels will fit all Defender models, past and present ![]() |
We run 255/85/16 tyres on standard suspension and on a 2" lift on our 110's. These tyres have a 33" diameter. No problems with a 33" diameter tyres on standard suspension.
Adjust your front steering stops so that the front wheels just touch the front radius arms for best turning circle. Brendan |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Cheers guys for the quick replies - what a top forum this is
![]() Mermoto |
JimC Member Since: 22 Jan 2011 Location: NOVA Posts: 164 ![]() ![]() ![]() |
Keep in mind that not everything fits perfectly out of the box. I just installed a set of ANR 1534 HD steel wheels ("old" d130/NAS 110 style) on my 09 Puma and I had to grind a few mms off the outside edge of the rear brake calipers for clearance.
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
I thought there were certain restrictions? Some 90's have a lower load rating that 110/130 models?
There was a thread warning that some wheels are lower-rated for weight than others... See LandRoverAnorak's reply to this thread:
http://www.defender2.net/forum/topic8203.html?highlight= Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Very true - however IIRC Mermoto has a 90 so should be ok. What Martin says is correct - although the studs and PCD is the same meaning the wheels will fit you need to bear in mind that not all the wheels are rated for a 110 or 130. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
And ... he did state 'Defender' wheels.
All will fit all ... earlier models were not actually 'Defenders', but Landrover 90. 110 etc ![]() |
They've been Defenders since 1991 but some wheels fitted since then are still not rated for the larger models - Freestyle ones in particular. If the OP has a 90 then it's not specifically an issue, but as a general statement, I'm afriad all won't fit all. Darren
Change fit for suitable
Yeah, of course. I was paraphrasing, but the reality is that whilst they'll all physically fit on the hubs, some just aren't suitable for some models. Darren
LOL ... but he didnt ask if they are/were 'suitable', only 'will they fit'? So yes, all will fit all ![]() |
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
A treestump with 5 holes drilled in will "fit" a Land Rover hub.... doesnae mean it'd make a good wheel though
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I dunno............ served Fred Flintstones needs well enough. ![]() ![]() |
