Home > Wheels & Tyres > Quick help
Stiff1
Quick help
Hoping for a bit of quick advice.
So my 2007 110 CSW on all standard set up with original boost alloys shod in BFG AT at 235 85 16 which will need replacing soon.
I have been offered a nice set of BFG AT 245 70 16....
So, will 245 be an issue with lock or going on the rims and will 70 look like a low profile on the Defender.
All personnel opinions welcome and any pictures of this setup would be appreciated.
Thanks in advance.
Post #944694 5th Mar 2022 10:39am
htb2
they will fit on the rims no problem, will be slightly smaller in diameter so will lower the gearing, turning circle should not be affected as small width change coupled with reduced diameter.
Post #944696 5th Mar 2022 10:52am
Screbble
Can’t speak from personal experience as I’m still using 235/85/16, but there are many on here who have upgraded to a wider tyre and have not experienced any insurmountable issues.
I do know that the 70 is the aspect ratio so you do need to keep an eye on that in terms of wider tyres and overall diameter as it might throw your speedo reading out.
Those with real/proper knowledge and experience will be along shortly to provide you with the info you require.
Good luck!
Post #944697 5th Mar 2022 10:54am
Stiff1
Thank you both, I think my concern is around them looking too low profile and other owners bullying me Laughing Laughing Laughing
Post #944699 5th Mar 2022 10:57am
Screbble
I can see what you mean now, but Defender owners don’t bully - only wave!
As you’ve requested, some pics will help you make your mind up Thumbs Up
Post #944701 5th Mar 2022 11:04am
camelman
They will look a bit weird on a 110 as the height is 2+ inches less than a normal 235 tyre.
You will also lose over an inch of ground clearance
Post #944702 5th Mar 2022 11:18am
X4SKP
I think you'll still have some margin of 'safety' before any bullying is appropriate...
 SKIP
Post #944703 5th Mar 2022 11:41am
Screbble
That reminds me of a Hot Wheels toy I once had Shocked
Post #944709 5th Mar 2022 1:17pm
Dinnu
You will probably never break a halfshaft, and you can remove 1st gear from the gearbox if it is a tdci.
But it will look weird. Had an acquaintance that had those tyres on a 90 HT. Never looked right. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #944710 5th Mar 2022 1:30pm
