![]() | Home > Maintenance & Modifications > Larger / add on Fuel Tank 2.4 Puma |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
I looked at options for our 90 too and concluded it is somewhat limited... if non-existent
in the end decided to KISS ![]() 20Lts = 100Miles ![]() Click image to enlarge I did like the possibility of utilising the space within the Spare Wheel (which I assume is reversed)... ![]() Click image to enlarge ![]() Click image to enlarge Although for us this is not straight forward... (projects Wheel and Can further back + additional weight on Carrier) ![]() Click image to enlarge So the Jerry Can is still the simple low cost route... SKIP https://www.defender2.net/forum/topic83242.html |
Deflandman Member Since: 01 Jul 2021 Location: St. Paul's Bay Posts: 2 ![]() ![]() ![]() |
Hi, do you have any pictures you can share? Is the one you installed the DA 4546? |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
Few versions are available - plenty of pictures via Google. Rgds.
Chris |
Thug Member Since: 02 Aug 2022 Location: Johannesburg Posts: 20 ![]() ![]() ![]() |
I have a 40lt auxilary tank on my 90 with an extra filler cap next to the drivers door. An electric pump connects it to the main fuel tank inlet pipe.
Can't tell you who provided it as already installed when I purchased the 90. |
Lightwater Member Since: 28 Jun 2020 Location: Sydney NB Posts: 74 ![]() ![]() |
I knocked up this bracket for 10L containers. 20L are too heavy to get on & off the roof. Maybe 10L containers are low enough for tollways?
Anodised aluminium & 316 stainless hardware. ![]() Click image to enlarge ![]() Click image to enlarge It's been over thousands of km of corrugated roads & no issues so far. Visitor - Freelander owner |
That is very neat
![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Apart from 4 x 10L, we also have 2 x 5L in the second spare wheel on the roof.
![]() ![]() The whole setup. ![]() (the chainsaw is not ours) Because they are a maximum of 10L you will actually get the fuel off the roof regularly as they are easy to handle. Visitor - Freelander owner |
cool stuff
