![]() | Home > Puma (Tdci) > No power to starter solenoid |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304 ![]() ![]() ![]() |
Hello ducaticam
![]() Click image to enlarge ![]() Click image to enlarge Is it 'turning over', 'clicking', or just nothing... ![]() https://www.defender2.net/forum/topic83242.html |
ducaticam Member Since: 21 Feb 2022 Location: Ayrshire Posts: 3 ![]() ![]() |
There is no power going to the solenoid, so it won't crank
To rule it out (or get lucky) I'd would swap out the Ignition Switch.
(suspect legacy Lucas part known to give up) LR039638LR ![]() Background reading and my fix... https://www.defender2.net/forum/topic56773-45.html SKIP https://www.defender2.net/forum/topic83242.html |
Thanks X4SKP, I've ordered a starter relay from LR, handy to have if it doesn't fix this issue, if not i'll get onto them again and order an ignition switch.
Many thanks for your replies ![]() |
![]() logical order to proceed...Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
