Home > In Car Electronics > Headlights flickering
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
I have changed the indicator stalk unit on my 110 300tdi as the old one was loose and now dipped beams don't work unless I hold the indicator back very slightly all the time I want them on. Main beam works fine either way just dipped doesn't work unless I do the above.
Anyone have any ideas?
Post #942778 17th Feb 2022 7:01am
It wasn't a Britpart switch, by any chance?
Sounds like you need to change it again for a good one! Big Cry
Post #942783 17th Feb 2022 8:12am
Will.I.AM
lol yes sir!
thanks Black Wolf, tbh a guy on facebook literally just said the same thing that it is my fault for buying a cheap indicator stalk!
Ill get a genuine on order now
Post #942786 17th Feb 2022 8:15am
Will.I.AM
so to resurect this thread guys - same issue with the new lucas unit and i also find that the interior lights dim at the same time as the headlights flicker - does anyone habve any pointers as to where to go first?
Post #947472 30th Mar 2022 6:44am
Screbble
Sounds like an earth issue.
Do you know where all of your main earthing points are? If not, the learned folk on here will assist.
Do you have a wiring diagram?
Post #947475 30th Mar 2022 8:05am
Will.I.AM
thanks Screbble, ill have a look later today.
Post #947522 30th Mar 2022 3:47pm
Front bulkhead engine bay side upper area and transfer box are typical locations for grounding points.
You could add a temporary ground directly to the headlights to see what that does.
As well as checking voltage and continuity with a Multimeter if you’ve got one.
Also a difference in voltage or continuity reading one side to another can be a tell tale.
Some grounding eyes are on their own dedicated input on the same stud, so you can get good ground continuity with one but not the other but both share the same ground stud.
When you are driving the connection is loose and give on and off contact hence the flickering you mention.
Especially if it only does it when driving.
A multimeter should be your friend here.
Good luck. πŸ‘πŸ» ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #947533 30th Mar 2022 5:32pm
Will.I.AM
thanks Steve, i didn';t get a chance to check it last night but i think i will trace the earth wire form the battery tonight and clean up any contact points it goes to - once i have done that il check it with a short drive and if i still have the problem i think you idea of checking with a multi meter is a god one. Ill try that after and report what i find when i do it. thanks
Post #947583 31st Mar 2022 7:17am
Thumbs Up ____\We|Will|Win/___
Post #947623 31st Mar 2022 2:16pm
