Home > Maintenance & Modifications > Gutter mounts for strapping - NOT for rack or bars???
ANelson78
I frequently have to take my 110 under a height bar, into local car park.
I also want to be able to occasionally strap my surf bords to the roof.
I can do this via a 'soft rack' set up. Basically 30mm ratchet strap and two foam pads.
So I am looking for a secure eyelet mount for the strapping that does not protrude above the roof line.
Plenty of brackets and mounts but all seem to be for attaching bars or a rack to.
in the links below
Wondered if anyone has a more elegant solution?
https://roofrack.com.au/product/roof-rack-gutter-clamp-long-each/
https://www.ebay.co.uk/itm/363678017076?ch...d1EALw_wcB
Post #942551 15th Feb 2022 10:28am
I'm not sure that what you're after is really possible. The problem with a gutter clamp alone is that it won't have any lateral strength and any force that you put on it, say with a ratchet strap, is likely to twist the gutter.
They only work with bars and racks because of the rigid junction with whatever spans across the roof.
I'd suggest a couple of roof bars as they only take a few minutes to fit. Darren
Post #942553 15th Feb 2022 11:37am
Hmm, I think you need an Ineos Grenadier, with its integral rubbing strips on the roof and its integral securing bars where the Defender has alpine windows! Very Happy
Post #942569 15th Feb 2022 2:42pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
I have a pair of Thule roof bars that are very quick to screw on/off; no tools required.
They could be yours for a small fee. Just not got around to posting them in the For Sale section yet.
Post #942586 15th Feb 2022 4:51pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
You could fit cargo tracking just below the gutter line then use clip in tie down rings, this would work better on a 2 door as you’d get a longer length for strapping, not sure if it would be long enough for a surf board on a 4 door.
This stuff…
https://www.mudstuff.co.uk/products/cargotrack-ltrack 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #942587 15th Feb 2022 4:59pm
Mo Murphy
Fit a roll cage. Works for me 😁
50 Shades of Pennine Grey
Post #942603 15th Feb 2022 5:38pm
Doesn't solve the height bar issue though... Darren
Post #942650 15th Feb 2022 10:18pm
ANelson78
Sounds good. Yes please
Post #942652 15th Feb 2022 11:05pm
ANelson78
Hm. Good point. I had thought the angle of pull would be mainly vertical, as the strap would have to go up over the roof, but having taken a second look I think you're right.
Post #942654 15th Feb 2022 11:06pm
steveww
How about https://www.mudstuff.co.uk/collections/car...ack-ltrack
Looks like you run the track just under the gutters.
Post #942723 16th Feb 2022 5:24pm
gcc130
Surely under the gutter would foul the doors opening?
Post #942738 16th Feb 2022 6:09pm
