![]() | Home > Puma (Tdci) > Power loss |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
I know, do a search, did that, but didn't find what I needed.
This last summer while cruising through Slovakia, I found that, with foot to the floor, the landi was slowing down...chalked it up to going up hill with air and fully loaded. Problem was solved with a quick on and off. Upon returning home i ran a scangauge and didn't come up with any faults. Yesterday, for the first time since then, it happened again. No air, loaded a bit. (probably makes little difference) Both times it has happened it was on drives of over 1/2 hour... A quick pull over, on off seems to fix the powerloss Runs fine afterwards with no memory of the problem Wife says it doesn't happen when she drives it... ![]() Any help as always is greatly appreciated John 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
Thanks for that. Yesterday, it was around 13C outside so, that might nix the high ambient temp part.
I will have to get it into my dealer as they seem to be pretty good and thorough...germans ya know.. 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
We're desperate for a solution, so please let us have them (if they find the fault).
I wonder if any of of the remap contingent on here have had similar problems, or if if the Egr/erg blocking club have Had similar issues? 2008 Defender 110 60 year Edition (sold unfortunately)
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
IIRC, someone else had this issue and found that opening the fuel cap helped. It could be the fuel filter and/or pump starving the engine of diesel? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
