Home > Puma (Tdci) > Check your nuts!
Happyoldgit
Check your nuts!
Greasing up the propshafts this afternoon and checking the securing nuts and bolts I found both the front prop to pinion flange and rear prop to output flange fixings were not tight. I know this is a known potential issue but just thought I'd mention it again, I discovered the same with both my last Puma and at least one of my previous TD5's as well. Steve.
http://forums.lr4x4.com
Post #93887 12th Oct 2011 5:59pm
good call MOG..
nuts all present and correct on both land rovers.
wd40'd the 90's rear prop ready for new wide angle (& balanced) prop replacement on the weekend
I bought the propshaft tool as well this time so fitting should be a breeze Thumbs Up
Post #93899 12th Oct 2011 6:49pm
Happyoldgit
I think it was the last TD5 110 XS I had which went in for an under warranty replacement rear pinion seal. I went over, collected the vehicle, drove it home but no matter how carefully I changed gear I realised there was a bit more clunking, play and vibration in the driveline than there was before. Got back, stuck it up on the ramps for a look-see and found the rear prop bolts were not fully done up Shocked Steve.
Post #93915 12th Oct 2011 8:19pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i had a clonk on my Puma, popped into the dealer and it was loose bolts on the trans brake flange. Shocked BM52
Post #93917 12th Oct 2011 8:26pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I don't want to appear lazy, not bothered to google etc, but, what torque should the prop bolts be set at? I'd like to check mine while it's still light outside! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #93959 12th Oct 2011 11:44pm
noworries4x4
Don't worry you can't over tighten the unf nylock nuts as they are made from the finest Solihull hardened "cream cheese" metal and thet will round off first guarenteed. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #94086 13th Oct 2011 8:11pm
