![]() | Home > Puma (Tdci) > Check your nuts! |
Greasing up the propshafts this afternoon and checking the securing nuts and bolts I found both the front prop to pinion flange and rear prop to output flange fixings were not tight. I know this is a known potential issue but just thought I'd mention it again, I discovered the same with both my last Puma and at least one of my previous TD5's as well. Steve.
I think it was the last TD5 110 XS I had which went in for an under warranty replacement rear pinion seal. I went over, collected the vehicle, drove it home but no matter how carefully I changed gear I realised there was a bit more clunking, play and vibration in the driveline than there was before. Got back, stuck it up on the ramps for a look-see and found the rear prop bolts were not fully done up
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i had a clonk on my Puma, popped into the dealer and it was loose bolts on the trans brake flange.
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I don't want to appear lazy, not bothered to google etc, but, what torque should the prop bolts be set at? I'd like to check mine while it's still light outside! ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Don't worry you can't over tighten the unf nylock nuts as they are made from the finest Solihull hardened "cream cheese" metal and thet will round off first guarenteed. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
