![]() | Home > Puma (Tdci) > Electric gremlins |
| Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2114
Hi there!
Im on vacations rigth now in the north of Chile with the family. Regrettably yesterday in a rougth grável road the Defender lost the speed, revs, fuel level, temperature dials etc. All dials going to 0. But the ligths works Ok Also both electric windows doesnt work. Defender entered in limp mode (limitando speed) and my ODB detected the code U0155 that I assume is related with the dials shutdown. I found 2 fuses burned and I change it. Work for some minutes but again burnout. So probably I have a shortcircuit some were My Indi change done of the windows lift system some days ago and is my first culprit Anyone with a similar problem? Any thought from were I can start? Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge Last edited by Eduardo on 27th Jan 2022 1:29pm. Edited 1 time in total |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Check the grounding points ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello Eduardo
I can't help on the reason why... but your thinking around recent work undertaken is a good place to start Re Your Fault Code... Click image to enlarge Which confirms Communication lost... fault finding is next step Good Luck... https://www.defender2.net/forum/topic83242.html |
Thanks
Can a bad earth blown the fuses? Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
Both driver doors were affected and fuse 9 ( ignition) blown.
I dont know why if fuse 9 go out , windows doesnt work Rigth now i remplace the fuse and all OK (only tarmac). Windows work properly and I have all the dials working. I move the looms Located near the firewall and the one located near the transfer and also the cable between the pillar and the door and Iwas not able to reproduce the fault. Earth was also checked and retighten. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
Looks that I have some random shortcircuit somewere.
A soon as I enter in a rough road the fuse blown The fuse blown was the N° 15 in the LR Electric wiring diagram. This fuse is the responsible of the "ignition" signal for several devices 1. Instrument cluster (ignition signal) 2. unit Timer heated front screen (not installed in mine) 3. Switch heated rear screen and the respective relay 4. relay headlamp (Bypassed) 5. Relay dim dip 6. Relay window lift and the window switch 7. Also probably when LR Chile installed an ignition live from there So, I will take out 3, 5, 6 and see from were 7 is coming Any other thoughs? Any other alternatibe? So Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
Problem found!
An old connection to take a ignition live from one of the electric window switch was not isolated correctly making shorcircuit with the radio case. Cheers to all! [/b] Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
