![]() | Home > In Car Electronics > Interior light |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Yes,
should be all doors and that includes the rear. Check the switch and or replace it. They are quite common to play up, you may find removing it and replacing it may do the trick without getting a new one. They can often get stuck. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Drevil Member Since: 03 Jan 2022 Location: Berkshire Posts: 149 ![]() ![]() |
Thought so, thanks. I’ll have a tinker with it
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
I would put money on wire to door switch. Mines gone a few times
Yeah, it’s a very common thing.
It is ground switched, for those who don’t know. I find sometimes merely pushing in the switch and releasing it quickly a few times will even do the trick. You can try it with the interior lights on. The rear one tends to be support more than any I find. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Presume it’s gone at the switch end as opposed to some other random location? Cheers |
Yes. The wire snaps at the connector that attaches to switch. In my experience
Thanks
Andddddd fixed.
Turns out that the auto electrician / moron who fitted the LED work light tapped into the OE wiring and pulled all the wires in silly directions meaning the pin switch could not fully extend. Clearly they were not a fan of soldering either……….. Some new wiring and bingo……………one working pin switch. |
