Home > In Car Electronics > Interior light
Drevil
2011 Defender 110 Puma 2.2 USW Indus Silver
Interior light
Before I start checking wiring etc, in a Puma 110 is the interior light meant to come on when the rear door is opened or just when one of the passenger doors is open?
Currently interior light is triggered by any of the four passenger doors, but not the rear (boot…what the hell do you call it??).
Cheers Tom
Post #939651 26th Jan 2022 10:55pm
Yes,
should be all doors and that includes the rear. Check the switch and or replace it.
They are quite common to play up, you may find removing it and replacing it may do the trick without getting a new one.
They can often get stuck. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #939652 26th Jan 2022 11:01pm
Drevil
Thought so, thanks. I’ll have a tinker with it
Post #939655 26th Jan 2022 11:18pm
landy andy
I would put money on wire to door switch. Mines gone a few times Embarassed Embarassed
Post #939658 26th Jan 2022 11:33pm
Yeah, it’s a very common thing.
It is ground switched, for those who don’t know. I find sometimes merely pushing in the switch and releasing it quickly a few times will even do the trick. You can try it with the interior lights on.
The rear one tends to be support more than any I find. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #939660 26th Jan 2022 11:48pm
Drevil
Presume it’s gone at the switch end as opposed to some other random location?
Post #939661 26th Jan 2022 11:55pm
landy andy
Yes. The wire snaps at the connector that attaches to switch. In my experience
Post #939680 27th Jan 2022 9:21am
Drevil
Thanks
Post #939681 27th Jan 2022 9:27am
Drevil
Andddddd fixed.
Turns out that the auto electrician / moron who fitted the LED work light tapped into the OE wiring and pulled all the wires in silly directions meaning the pin switch could not fully extend. Clearly they were not a fan of soldering either………..
Some new wiring and bingo……………one working pin switch.
Post #941112 5th Feb 2022 3:04pm
