![]() | Home > Technical > Help! Loss of power, boost leak? 2.2 TDCI |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
check charge air pipe work engine bay for splits or disconnected hoses good place to start and check DTC from ECU
NO throttle body but this a ford engine and junk to boot Last edited by dorsetsmith on 23rd Jan 2022 8:39pm. Edited 1 time in total |
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
Do d you check all 3 hoses?
There’s a little 90degree elbow one. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6728
If it's passenger's side it's highly likely to be the elbow under the throttle body (yes, 2.2s have one!) on the inlet manifold side.
Get your hand underneath it and prod the hose to see if you can open up a split. Impossible to visually inspect it as it's buried behind coolant pipework. You won't get any smoke due to the DPF. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
See here for mine recently. Split couldn’t be seen, it was in the underside of the hose. Sounded just like yours though: https://www.defender2.net/forum/topic81670.html |
Here:
Click image to enlarge When changing it, I decided not to remove the coolant hoses to save time, but it probably cost me more time by not doing so. Give me a shout if you want any hints and tips. |
| Andy RV Member Since: 26 Apr 2014 Location: Somewhere Posts: 66
Cheers guys, I’ve removed the three hoses, including the 90’ elbow which joins the throttle body and they all look fine. I’ve cleaned them up and done my best turbo impression by blowing through them in the kitchen sink while blocking the other end with my hand and I can’t detect any leaks or splits…! I’ll see if I can borrow or buy a code reader tomorrow😟.
“ done my best turbo impression by blowing through them in the kitchen sink”
| JPE Member Since: 19 Nov 2018 Location: South West England Posts: 347
I've had 3 separate boost leaks with limp mode in 3 years. Once the hose into the inlet manifold, once the hose out of the intercooler, but the other time it was a split in the intercooler itself. Might be worth checking if all 3 hoses are ok.
| piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 237
Hey Andy RV
It is very hard to ascertain where the hole is as it only makes the sound when the engine is running under load (ie when the turbo is spinning). You can find the leak with the engine off by using a piece of plastic pipe, blanked at one end with a cap (cap needs to be glued on). A scrap valve (from a bike inner tube) is first fitted through a hole in the blanking cap prior to gluing the cap onto the pipe. Leave a bit of a flange on the base of the valve (you wont need any glue to hold the valve as the air pressure will seal it as long as its a tight fit). Click image to enlarge Disconnect the boost hose from the turbo outlet and connect the plastic pipe to the boost hose. Then pump in air using a bike pump. When the system starts to pressurise you should clearly hear where the air is escaping (you shouldn’t need too much pressure). Click image to enlarge Andy Last edited by piechipsandpeas on 25th Jan 2022 2:25am. Edited 2 times in total |
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
Love the test rig Andy
Brilliant! I’ll knock one of those up!
I put the hoses back on last night, I’ll take it for a run later today and see if I can narrow down the symptoms. |
Progress thanks to Andy’s pipe & pump pressure thingymajiggy! The intercooler has split;
Nice bit of problem solving there! Good excuse to buy yourself a fully welded uprated intercooler as well!
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2541
What a great tool, simple , yet brilliant and cheap
What size pipe did you use ? |
