![]() | Home > Puma (Tdci) > Output shaft failure, Forum Survey |
| nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 |
His local pharmacy may go out of business!
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
I guess that wouldn't work |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
My opinion, if it failed at 32k miles, go for Ashcroft. Thats because it can allow a bit more misalignment, and if it has to go again, you replace the shaft only, not the gearbox or transfer case. There is no information/data of what happens with a solid shaft when there is misalignment. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| Jpw110xs2015 Member Since: 22 Jan 2022 Location: Hampshire Posts: 4
Dinnu, thanks for the feedback. I guess any replacement will be stressed if misaligned.
That is the hypothesis. Some Defenders can reach very good milage, some not, and the most plausible root cause is misalignment between the gearbox and the transfer case. These are mated with an adaptor housing, both ends are doweled, so most likely some had higher inaccuracies than others. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Dinnu, I appreciate your knowledge and explanation, 110 currently in the garage, I will discuss with the technician tomorrow morning, once again thanks.
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
Report post
1. 2011 90HT 2. 2.4 3. Y still original 4. 60k miles Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
2015 110xs os failed 32k miles
| Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 626
It is four years since I posted in this thread. Five years since the shaft was replaced Og shaft was replaced at 40k with genuine parts. Now on 112k and all good. Alignment will be the same so why has one lasted so much longer than the other?
thanks for throwing that in and ruining our theories
interesting |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Whose theories? Maybe all theories are not equal? Genuine replacement included grease...factory install excluded grease, Ashcroft solution is to wet a dry spline. Go figure... |
Other than stating the obvious? |
you may find there's a very large number of wet installs that have failed.
take my second failure for example. |
Can you be more specific ~ who's wet install?
