Home > Maintenance & Modifications > Galvanised Replacement Doors
Page 2 of 3 <123>
Ghound
United Kingdom 1999 Defender 110 Td5 SW Alaska White
From the pics it seems your door skins are made from Zintek, there steel with a micro coating of zinc, so be sure you paint them well as they will rust out very quickly if not, once they get wet between frames and skin they will corrode.
The coating is really only to protect the steel while in storage it doesn't protect the same as galvanised steel skins.
bodstruck wrote:
Well, they turned up quicker than I was anticipating. Well packaged and an initial inspection shows not damage. How well they fit remains to be seen but no reason they should not be good Thumbs Up
What prep do I need consider? The galv is a bit rough so am I safe to sand that down? Presume then some etch primer and then top coat. These are not going to be sprayed, I will either use coach enamel or rustoleum combicolour applied with brush and roller.
Post #938984 23rd Jan 2022 1:15pm
Caterham
can I enquire as to why you won't be spraying them? Thumbs Up
Post #938997 23rd Jan 2022 2:14pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
I agree with this. As a sheet metal worker in a previous life, I can assure you zintec gives very limited protection. Treat it as if its mild steel. If anything has been spotwelded that is an area that is likely to be subject to corrosion. Remember any galv/zinc would be burnt off when when the weld takes place. The real area to consider is between the two pieces where the spotwelded is. If these areas are where water or moisture will sit it will be a real contender for corrosion. You need a good penetrative rust inhibitor here.
Post #939003 23rd Jan 2022 2:26pm
Mo Murphy
@ghound - Robert, any plans for Front doors to match my galv rear door ?
50 Shades of Pennine Grey
Post #939010 23rd Jan 2022 2:50pm
Ghound
Hi, yes I'm serious considering making them, but they wouldn't be exact copies, I'd like to make them a bit tougher.
Post #939012 23rd Jan 2022 2:53pm
Mo Murphy
Sounds good, I'll wait with baited breath 👍
Post #939031 23rd Jan 2022 4:34pm
Mossberg
Looking forward to seeing this. Good luck with it.
Post #939034 23rd Jan 2022 4:47pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
I thought that my doors from SP were skinned with Zintec, but the description below states that their steel skins are electroplated:
https://www.sp-4x4.com/category_s/437.htm
Post #939070 23rd Jan 2022 6:50pm
Mossberg
Just for your information. I picked this from the Web;-
Zintec is created by using the process of electrolysis to coat the mild steel with a thin layer of zinc, typically between 1.0 and 1.75 microns thick, a more precise method of zinc coating than other methods such as hot dipping.
The finished Zintec metal can be produced at varying thicknesses between 0.4 and 2.0mm, with a matt grey finish that is notably different to untreated mild steel. It is important to note that Zintec is designed to protect the mild steel during transport, storage, manufacturing and production processes; it is not suitable for use in corrosive environments without a paint coating or other protective application
Post #939087 23rd Jan 2022 8:08pm
Ghound
I make all the components including the skins
anyways as i restore original doors, so it shouldn't be a big leap to make my own version.
Mo
Post #939107 23rd Jan 2022 10:01pm
Mossberg
That's interesting. Have you considered doing a stainless steel version?
Post #939121 24th Jan 2022 2:17am
bodstruck
Facilities and cost really. I had a Clarke temporary garage while I painted the td5 but that has gone now so I don't really have anywhere suitable for spraying. I do have a concern about getting in to the nooks and crannies inside the door so the priming may be a mix of rattle can and brush. For the topcoat I will be going for a satin finish and I have found brush and roller to be perfectly adequate for my needs, loads cheaper (as I can do it myself) and easy to patch or re-do in the event of scratches or damage.
Post #939216 24th Jan 2022 1:52pm
Ghound
Stainless is a lot harder on the machinery to work with, it wouldn't be something I'd consider doing.
Post #939374 25th Jan 2022 10:11am
Mossberg
I fully understand but it's a shame as what a bonus that would be - though they would probably be out of my price range!
Post #939396 25th Jan 2022 11:56am
Dinnu
Some people go to great lengths to isolate steel fasteners to minimize galvanic corrosion. Stainless steel is a bit further away than aluminum on the galvanic table so the galvanic reaction is larger due to greater potential. Having huge stainless steel panels fitted to each side of a defender is asking for trouble.
Galvanized (not zintec) sheet metal is the best material. Most manufacturers give life times in excess of 30 years (bare galvanized) in relatively corrosive environments, like gutters etc. The reason that galvanizes steel has such a good life is the huge surface are of the zinc compared to the exposed area of the steel.
Maybe galvanized doors may protect your chassis (although I doubt) Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #939489 25th Jan 2022 6:13pm
Page 2 of 3 <123>
