Home > Puma (Tdci) > HELP My truck wont start ??? HELP
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
hi guys
im in a bit of a dialema my truck wont start
went to move it after going out this morning and all it does when you turn the key is click
but whilst turning the key the headlights come on also the rear fog light and the handbrake cable sleeving has melted around the cable as it is getting extremely hot when im trying to start it ?
im aware it most prbly an earth problem and have had a good look and fiddle about but with no luck atall
it has 2 odssey pc 1500 batterys on it so shouldnt be down to a bad battery
does anyone have any ideas or exsperience where they ave had the same problem
answers on a postcard lol
cheers guys
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #93880 12th Oct 2011 5:30pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Check the battery cables where they go through the seat box Question Original Member Pie n Pea Club.
110 HCPU Tipper
Post #93881 12th Oct 2011 5:39pm
Martin
Site Admin
It's earthing through the handbrake cable. Try connecting a SINGLE jump lead between the battery negative terminal and something bare metal on the engine, to create a good earth return path.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #93882 12th Oct 2011 5:40pm
K9F
Martin's idea sound a good fix! If indeed the whole electrical system is earthing out through the cable. If not it could be another system and with all the parallel paths it could be a system dragging the rest down possibly....
Remove all the irrelevant fuses, lights, wipers etc. etc. and try again, you need to isolate whatever system appears to be shorting to earth through the handbrake cable. You can then restablish the system fuses one by one to try and source the problem. Good luck! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #93884 12th Oct 2011 5:50pm
big steve
well just tryed what you said martin (dont know why i didnt think of it ) oh yer i was to busy kicking the thing in
lol
it started so first thing tommorow im going to take the earths of and give them a clean and replace and try again
cheers guys im glad that wasnt as abad as i thought #
Post #93886 12th Oct 2011 5:57pm
K9F
Excellent news! 27 minutes from posting to resolution!!! Wonder if that's a record??? Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #93889 12th Oct 2011 6:04pm
LR90XS2011
earth cable from chassis to engine / gearbox would be where I would look first especially if you get it wet and dirty a lot good luck DEFENDER 90 TDCI XS,
Post #93891 12th Oct 2011 6:11pm
big steve
yep going to have a good look there tommorow
cheers all 2015 2.2 tdci hardtop xs
Post #93898 12th Oct 2011 6:49pm
same happened to my on my old '91 disco .. some things never change
Post #93900 12th Oct 2011 6:51pm
big steve
well after removing the earth from the chassis and giving it a good clean and bit of copper slip before replacing the nut it had no affect still wouldnt start
so i then removed the earth to the transferbox giving the tab a good rub down with a wire brush and the bolt a good spray with copper slip and replaced it
She fired back into life first turn of the key
the big down side to all of this is that it has earthed the handbrake cable so badly that i have now got no working handbrake and have had to order a new cable Rolling Eyes 6o quid later for a genuine one
So i thought its worth mentioning before you get in this situation it could be worth getting undr your trucks and jsut giving those earth straps a check and clean before you get and reasonably exspensive problem like me
exspecially if you have to get a dealer to sort the problem out
thanks for everyones help on this matter
kind regards steve 2015 2.2 tdci hardtop xs
Post #94024 13th Oct 2011 3:08pm
good post steve, certainly one to add to the winter check list
Post #94047 13th Oct 2011 5:29pm
