Home > Maintenance & Modifications > Wheel bearing - sense check please
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Folks,
2 wheel bearing questions ...
1) Is ANY vertical play on a wheel when you rock it to check the bearing acceptable ? To my mind the answer to this is always no but I'd appreciate a sense check in case Defenders are different.
2) Typically does a new Defender bearing take a little time to bed in and then potentially require a little adjustment ? My only other experience of wheel bearings is on MG's which typically do require a little adjusting following replacement.
Reason I ask is that my ns front wheel baring was replaced a couple of weeks ago, and this weekend, I decided to check the other three. All where rock solid and then out of curiosity I checked the ns front and there was a little bit of vertical play.
Logic says if the other three are solid then so should the replacement but always good to check/learn so I can go back to the garage
Cheers, Jon - 110 td5 [sold]. Currently Defenderless.
Post #71107 16th May 2011 8:49am
BigMike
No and no
Post #71113 16th May 2011 10:20am
party monkey
Muchos gracias Mike Thumbs Up Jon - 110 td5 [sold]. Currently Defenderless.
Post #71123 16th May 2011 11:40am
party monkey
Resurrecting this post as getting a little suspicious about the NSF wheel bearing again..... Shocked
Out of the blue on the journey to work this morning, seemed to be excessive road noise.
Just jacked up all four corners in turn in the office car park (much to amusement of the smokers!). No play on any of the wheels when rocked vertically but the NSF wheel when spun appears to make a slight 'clonk' on every rotation.
Could this be a sign of a problem with the bearing again?
She's due in to my local indy for a service early next week anyway, so it's been added to the list for investigation. Jon - 110 td5 [sold]. Currently Defenderless.
Post #93855 12th Oct 2011 1:25pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Well something is definetely 'not right' on the n/s/f corner.
could be bearing, or any other component there [swivel/hub/ wheel mounting etc]
Best to get it checked asap ... Guns and Landrovers .... anything else is irrelevant.
Post #93883 12th Oct 2011 5:42pm
party monkey
Cheers Dave, Thumbs Up
Deffo something not right as the road noise 'roar' appears more pronounced again this evening and if anything there is a little wander in the steering ..... or this could just be my heightened sensitivity to what's perfectly normal and I'm looking for problems.....
Still, she's going in next Tuesday and I've no major need to use her in the meantime..... I feel a couple of days of 'working' from home coming on Whistle Jon - 110 td5 [sold]. Currently Defenderless.
Post #93904 12th Oct 2011 7:05pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i had a very similar problem on a 300, it turned out to be the top swivel bearing was knackered? BM52
Post #93918 12th Oct 2011 8:34pm
jst
if the play is just in the vertical plane but not in the horizontal plane then its likely to be swivel pin wear. most likley and best case is adjust the top preload on the kingpin, worse case bottom bearing failure.
if the play is in all planes ie 3 & 9, 4 & 10, 12 &6 etc etc then wheel bearing needs adjustment.
the new ones have a use once spacer that the out nut is torqued against. it may not of had the correct torque applied. or change them back to the old style two nuts and fold down washer - easier to maintain if wheel bearing issue is a problem. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #94132 13th Oct 2011 11:51pm
noworries4x4
If you have just had one changed the outer bearing race might not have been pressed fully home in the hub and it has now settled home and now needs adjusting up again. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #94135 14th Oct 2011 12:13am
The new ones should be torqued to (if I recall correctly) 150lbft and the sacrificial nut staked. Not long after I bought my '07 I found that both rear hubs were loose and the nuts had clearly not been tightened correctly (or the hub had been assembled with the bearings improperly seated). There is no evidence at all that the hubs had been dissembled since leaving the factory, so I wonder if there was a 'Friday' problem with some vehicles.
I also suspect that some mechanics may not know that these should be so tight and may use the old tighten-until- there's-no-play approach that applied in the double nut & tabwasher days.
Post #94184 14th Oct 2011 9:51am
party monkey
Turned out to be slight play in the swivel joint. Nothing too drastic to make it dangerous (their words!) but certainly needs attending to sooner rather than later.
Indy didn't have time or indeed the parts to fix today, so she's re-booked for next week.
Thanks to all for your input Thumbs Up Bow down Jon - 110 td5 [sold]. Currently Defenderless.
Post #94929 18th Oct 2011 7:56pm
jst
as above then!
glad they found the issue.
if you had replied with to above, we could of talked you through it! Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #94959 18th Oct 2011 9:49pm
party monkey
jst wrote:
as above then!
Cheers James, appreciate the offer but you forget you are talking to a mechanical numpty Embarassed
Indy also mentioned that the seal had gone too and there was talk of why shims wouldn't work in this case etc etc... At that point my eyes had already glazed over and I uttered those eight magic words.
'How much and when can you do it'
They're a decent indy with a good solid reputation locally (used them before too, always very good) so I'm totally cool with letting them sort it. Jon - 110 td5 [sold]. Currently Defenderless.
Post #94980 18th Oct 2011 10:56pm
