Home > Tdi > Oil Leak from where?? Defender 90 Tdi300 (1994)
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
Hi folk
I was out and about for a couple of hours this morning, came home, parked up then about an hour later went to the Defender and noticed a small pool of oil on the floor ...
Got underneath and took these shots. Number 3 was where I wiped off some oil:
Can anyone tell me the proper oil pipe titles/purpose and can anyone share there experiencies please.
MTIA
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #938763 22nd Jan 2022 12:37am
landy andy
I think that is your power steering pump, and it’s pipes. Is the fluid dark red?
Post #938765 22nd Jan 2022 12:46am
Cubflyer
Hi Andy ... I'm pretty sure it was black like dirty engine oil the the pool on the floor was definetly black. 2010 Defender 90 300Tdi CW (White/1994)
Post #938767 22nd Jan 2022 12:49am
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Your second image shows the drain in the timing belt cover. If that gas oil coming from it then it could be the crank shift oil seal. This I believe is a cam belt and pulls off to replace the seal. Have you had the timing belt replaced?
You have a very tidy looking truck there with not too much oil. Hopefully this will help you identify the leak.
I have several leaks to look into so I will watch this with interest as I am only just beginning on the road of defender self maintenance so have lots to learn!
Post #938778 22nd Jan 2022 6:07am
Cubflyer
Morning Mick - Thanks for your comments, going to get underneath again today and do it bit more cleaning then run it to pin the leak down. Maybe it is not the steering hose area as first thought Question
As I replied to Andy above, not red fluid but black: Watch this space Exclamation 2010 Defender 90 300Tdi CW (White/1994)
Post #938783 22nd Jan 2022 8:32am
Mossberg
It may be worth trying to clean inside the drain hole too. A rolled up cloth with some brake cleaner on to remove as much oil as you can, then something clean at the end to check how clean it is.
Watching with interest as I have a leak/leaks that I need to identify them. I think one of my is the rear crank - joy!
Post #938800 22nd Jan 2022 10:46am
Dinnu
I find it baffling that you have oil on the steering drag link. That is quite forward (somewhere under the front cross member, just behind the bumper). So could there be a tiny leak in the intercooler... but really guessing. How if the front cross member, is it dry? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #938822 22nd Jan 2022 1:48pm
Cubflyer
My Defender came back from a Cam belt change today and the oil leak fixed too. A seal has been replaced which led to the oil leak dripping out of the timing belt breather hole ...
Another fault fixed Very Happy
Thanks for all your inputs Thumbs Up 2010 Defender 90 300Tdi CW (White/1994)
Post #941870 9th Feb 2022 11:19pm
