![]() | Home > Puma (Tdci) > Newbie random question |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3588 ![]() ![]() ![]() |
I guess you are talking about the plastic cover under the battery compartment under seat box.
The small pipe is the battery breather. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
As mentioned or aircon drain.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2428 ![]() ![]() |
Battery vent tube ?
You guys beat me to it ![]() |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1008 ![]() ![]() ![]() |
Quick responses. Thank you all. So assuming I hadn’t seen it before because this one was an XS with air con etc.
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1124 ![]() ![]() ![]() |
As above it's the battery breather. Air con drain can't be seen as it's above the gearbox. If you don't see a puddle of water roughly underneath the gear sticks, the air con drain is blocked and you might get wet feet
![]() oh, forgot: Croeso! ![]() |
Ooops. Didn’t notice we were talking tdci.
