Home > Puma (Tdci) > Newbie random question
BrickBox
Hi all.
I am slowly gathering information and knowledge around TDCi’s.
I have one random question - I saw a 110 utility with a plastic cover on the underside bolted to the chassis. It has a breather pipe coming out of it. Would anyone have any idea what I had seen?
It is located roughly under the passages side door area.
Thank you.
Post #937609 13th Jan 2022 9:58pm
Dinnu
I guess you are talking about the plastic cover under the battery compartment under seat box.
The small pipe is the battery breather. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #937614 13th Jan 2022 10:10pm
landy andy
As mentioned or aircon drain.
Post #937616 13th Jan 2022 10:14pm
Ianh
Battery vent tube ?
You guys beat me to it Very Happy
Post #937617 13th Jan 2022 10:18pm
BrickBox
Quick responses. Thank you all. So assuming I hadn’t seen it before because this one was an XS with air con etc.
Post #937619 13th Jan 2022 10:22pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
As above it's the battery breather. Air con drain can't be seen as it's above the gearbox. If you don't see a puddle of water roughly underneath the gear sticks, the air con drain is blocked and you might get wet feet Whistle
oh, forgot: Croeso! Wink
Post #937623 13th Jan 2022 10:34pm
landy andy
Ooops. Didn’t notice we were talking tdci. Embarassed Embarassed
Post #937703 14th Jan 2022 3:05pm
