![]() | Home > In Car Electronics (L663) > Front Interior Courtesy Lights |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Sounds broken to me Mike
haymeister Member Since: 24 May 2021 Location: Saitama Posts: 280 ![]() ![]() |
yeh seems so... it's not a deal breaker. Seems others (with MY22?) don't have this issue.
I don't want to waste hours unless the dealer can do a pick up and courtesy car. |
Take it in, let them do a while you wait diagnostic, then return for the replacement. If it’s the module it takes about 15 minutes to pop out, plug in a new one and test.
I wouldn’t bother with a courtesy car, I would just wait for it (or offer to fit myself) Mike |
JayZTampa Member Since: 08 Sep 2021 Location: Tampa, Florida Posts: 11 ![]() ![]() |
Pretty sure it should work...i don't think it is an "option". That being said, the interior lights don't seem that bright to me.
Your in Florida, sun is so bright everything is not as bright lol (I have a number of American friends around Tampa) Mike
The central light is present, but the switch to trigger does not work.
Will bring it in when I have a moment. I upgraded the boot, door, and footwell lights to the plain white LED ones from Powerfuluk. Makes a huge difference. Also installed the LED lightbar for the boot that they do in conjunction with Defender3D. Absolute night and day. Well worth it. |
Very True -mse
TomekW Member Since: 21 Feb 2015 Location: Warsaw Posts: 197 ![]() ![]() ![]() |
@haymeister, did you get the central light on/off switch topic solved?
I have the same issue. Thanks for info 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
Unfortunately not. Have been in and out of the country... but I will have to. It's annoying as the kids need it to put on their safety belts. I've resorted to opening the door which is great when it's -10 outside. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof
IG defender_japan "Hulk san" |
Finally brought it into the dealers to get this sorted amongst other things.
It is a fault. They will order the part, apparently the entire console has to be exchanged. 22MY Defender 110 D300 S in Pangea Green and Contrast White Roof IG defender_japan "Hulk san" |
thanks for update, really appreciated
will call my dealer early next week 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
visited dealer today replacement parts ordered thanks for hint! 2021 Defender 90 D250 1998 TUL 1997 TUM FFR 2003 Defender 110SW Td5 1985 ExMOD 110 ST 3.9 V8 1971 Series IIa Lightweight |
![]() IG defender_japan "Hulk san" |
