Home > Td5 > question about spring mount and connector |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2874 |
That’s a spring Mount
11th Jan 2022 10:32pm |
mruniversum Member Since: 18 Dec 2021 Location: Hessen Posts: 11 |
Yes of course, you're right.
same question: that plate should not look like this...? |
11th Jan 2022 10:37pm |
connector for near the diesel filter?.. is for
Click image to enlarge filter water sensor And how can I remove the diesel pipes from the filter (without destroying it:-) ? push gray peace in on both sides Click image to enlarge and at same time pall pipe off Laser Tools 4505 Fuel Line Pliers will help |
11th Jan 2022 11:12pm |
thx @dorsetsmith
So for removing the pipe I just have to press both pins at the same time, dont have that nice tool. The water sensor is standard or optional on the td5? There is a filter from "Mahle" mounted, are there filters available with and without the sensor? I found a kind of cap / valve at the bottom on the filter, seems to be its for draining the water...? btw, if I remove the filter / the pipes , do I have to (how?) release the preassure from the diesel pipes? (could be also done by the cap / valve on the filter) |
12th Jan 2022 9:18am |
water sensor is standard on pre 2002 td5 (but no in put ecu only indicate on dash)
Pressure from the diesel pipes? only 0.5 Bar from pump and fuel retune engine |
12th Jan 2022 9:54am |
