Home > Maintenance & Modifications > Problem with Optimill Steering Lock
Hello folks,
I've noticed in the past that it becomes harder to push the lock in on my steering lock when the weather is cold and the last few days were no different. However, yesterday I also struggled to get the lock to release again, which was something of a concern as I was in a public car park in Guildford! As a consequence, I'm reluctant to refit it at the moment.
I'm presuming that it's a tolerance issue in the mechanism but there's no obvious way to adjust or dismantle it. Has anybody else come across this or can offer any pointers? Darren
Post #936801 8th Jan 2022 11:27am
landy andy
Are you talking about steering wheel boss lock?
Post #936805 8th Jan 2022 11:49am
Assuming that you do mean the Optimill lock, it is not something that I have noticed on mine. Have you tried lubrication?
Post #936824 8th Jan 2022 2:11pm
Yes, the boss lock. Is there any other? No, I haven't tried anything as yet. I did contemplate some graphite powder but other than directly into the lock, it's not really obvious where would be best to apply it. That's why I thought I'd try here first, to be honest. Darren
Post #936826 8th Jan 2022 2:18pm
jonesie
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Corris Grey
Have you spoken to Optimill Darren? Series I 86" Petrol orig side valve (daily hack)
VW Tiguan ( bit bland but very comfy )
Porsche 997.2
790 Bonnie
Post #936828 8th Jan 2022 2:30pm
No, not yet - it only happened yesterday afternoon. I'll have to give them a try next week. Darren
Post #936831 8th Jan 2022 2:43pm
jonesie
When mine came it had a thin film of oil on the shaft, perhaps a bit of something like olive oil or a similar might stop it…..
Must admit it was cold yesterday morning but it worked fine. Series I 86" Petrol orig side valve (daily hack)
Porsche 997.2
790 Bonnie
Post #936833 8th Jan 2022 2:48pm
landy andy
Mine is fine no problems at all, but can be a Censored to pull the locks out the wheel. Possibly a tolerance thing with the cold.
Post #936838 8th Jan 2022 3:29pm
Landymatt
This is my second full winter with mine and not had any issues with the cold, even when windscreen etc well frozen.
My boss lock got less and less easy to slip on with time, so popped some graphite powder in the three holes in the boss lock and it made a big improvement.
Recently noticed the pin that I normally use to line up the holes and the pins (ie press my finger against) is showing signs of corrosion so will be putting a dab of something on there at some point.
Post #936846 8th Jan 2022 4:13pm
Just realised that I never closed this one out.
Closer inspection showed a burr on the top of the central pin, which I think was catching on the edge of the side pin with the 45 degree point on the end. I don't know whether it's always been there or has developed over time through use but the chances are that because of the way I mount and lock it, the two pins meet at the same spot every time. It's a Censored to photograph but hopefully this gives the idea:
My solution was to file a chamfer on the edge of the central pin. Again, bloomin' awkward because of its location but I persevered and ended up with this:
I also added some graphite powder, which seemed to go everywhere and is why the picture is so speckaldy! Anyway, it now locks and unlocks smoothly and easily, which is nice Smile Darren
Post #945791 14th Mar 2022 9:03pm
