Home > 130 > 130 td5 rear seat belts and anchorage - help needed
mruniversum
Germany 2000 Defender 130 Td5 HCPU Scotia Grey
Dear all and owners of a 130 td5,
I could really need some help, searching since days to get the correct parts for my 130 td5 from 2000.
I need all the seat belt parts for the rear seats (original bench seat will be replaced with 2 single seats).
I found out that BTR5779 should be the needed belt, but when I watch my car, I see only two bolts. Anything is missing here (pls check attached picture).
The BTR5779 (check picture) would not fit, because any anchorage seems to be needed.
In the dephts of the internet I found a picture where you can see anything like the part I need (attached).
If you have a 130 td5, could you please check how the rear seatbelts are mountet to the chassis? please take a picture of that, it would be really great.
We're family of 4 from germany and bought a defender "bushcamper" some month ago, with only two seats. Thats the reason why we have to rebuild everything in the back of the cabin, including belts, seats etc.
many many thanks!
current situation in my defender, two bolts for any anchorage:
found in the internet, cant see enough:
Thats the belt I think I need, it has only one bolt:
Post #934084 18th Dec 2021 10:16am
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Not sure the part number is correct, but for the L/R seats (so not the one in the centre) you need something as pictured here:
see https://www.lrworkshop.com/diagrams/land-r...ront_53633
(note that the part nr is different for left and right) Defender 130 HCPU Td5 MY2000
Post #934141 18th Dec 2021 7:48pm
mruniversum
thx@RoadForce for the link.
I checked all diagrams for belts and anchorage, but cant identify a part which looks correct for my 130 MY2000.
It looks like we both driving the same model? Do you still have seats / the bench at the back? If you would you be so kind to make some pictures?
Post #934150 18th Dec 2021 8:46pm
RoadForce
Mine came without rear seat and belts, so I had to retrofit them myself. Consequently, mine is not "stock" but I am fairly sure it is very close if not identical to how it would have left the factory. I used similar seatbelts as the ones in the diagram. Defender 130 HCPU Td5 MY2000
Post #934166 18th Dec 2021 10:20pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I'm currently replacing rear half of frame and nearly all steel parts holding rear end of cab on Def 130 2006 and the drawings are right - the same as what I had to remove (with grinder), and made new.
I have quite a lot of pictures from inside and outside end of the cab, but not for public share at this moment. Possibly later, but no problems to share it private. Just let know. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #934249 19th Dec 2021 4:19pm
mruniversum
If I check the diagram from RoadForce,
I find the part:
AWR2001
with additional information:
This part has been superseded by EVB000540LNF
And when I check part EVB000540LNF the picture looks different from the mounting part from the diagram Sad
Post #934343 20th Dec 2021 8:40am
RoadForce
That picture shows a "true" front row seatbelt: it attaches to the floor ánd the door pillar. The 2nd row seatbelts in a 130 attach to the floor only, since there's no pillar behind the seats. As to which part nr you need to order, I don't know and I understand your confusion. Defender 130 HCPU Td5 MY2000
Post #934509 21st Dec 2021 10:46am
mruniversum
dear all,
I got some usefull pics by MadTom and ordered some parts at lrdirect, hopefully they will fit..
I will let you know, and thanks again @MadTom!
Post #935015 25th Dec 2021 10:32am
mruniversum
FYI
I ordered the parts at lrdirect and they fit!
So If anybody have the same problem like me, following parts are needed for 130 td5 back seats outer (bench):
- BUCKLE RH BTR4372.C8
- BUCKLE LH BTR4373.C8
- HALF BELT BTR6561.C8
- HALF BELT BTR6562.C8
Post #937308 12th Jan 2022 9:09am
RoadForce
Good to hear you managed to sort it out. Kind of you to post the correct part numbers for anyone that might have to deal with the same confusion in the future... Defender 130 HCPU Td5 MY2000
Post #937394 12th Jan 2022 6:51pm
