![]() | Home > 130 > 130 td5 rear seat belts and anchorage - help needed |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 357 ![]() ![]() ![]() |
Not sure the part number is correct, but for the L/R seats (so not the one in the centre) you need something as pictured here:
![]() Click image to enlarge see https://www.lrworkshop.com/diagrams/land-r...ront_53633 (note that the part nr is different for left and right) Defender 130 HCPU Td5 MY2000 Last edited by RoadForce on 12th Jan 2022 6:48pm. Edited 1 time in total |
mruniversum Member Since: 18 Dec 2021 Location: Hessen Posts: 11 ![]() ![]() ![]() |
thx@RoadForce for the link.
I checked all diagrams for belts and anchorage, but cant identify a part which looks correct for my 130 MY2000. It looks like we both driving the same model? Do you still have seats / the bench at the back? If you would you be so kind to make some pictures? |
Mine came without rear seat and belts, so I had to retrofit them myself. Consequently, mine is not "stock" but I am fairly sure it is very close if not identical to how it would have left the factory. I used similar seatbelts as the ones in the diagram. Defender 130 HCPU Td5 MY2000
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 689 ![]() ![]() ![]() |
I'm currently replacing rear half of frame and nearly all steel parts holding rear end of cab on Def 130 2006 and the drawings are right - the same as what I had to remove (with grinder), and made new.
I have quite a lot of pictures from inside and outside end of the cab, but not for public share at this moment. Possibly later, but no problems to share it private. Just let know. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
If I check the diagram from RoadForce,
I find the part: AWR2001 with additional information: This part has been superseded by EVB000540LNF And when I check part EVB000540LNF the picture looks different from the mounting part from the diagram ![]() ![]() |
That picture shows a "true" front row seatbelt: it attaches to the floor ánd the door pillar. The 2nd row seatbelts in a 130 attach to the floor only, since there's no pillar behind the seats. As to which part nr you need to order, I don't know and I understand your confusion. Defender 130 HCPU Td5 MY2000
dear all,
I got some usefull pics by MadTom and ordered some parts at lrdirect, hopefully they will fit.. I will let you know, and thanks again @MadTom! |
FYI
I ordered the parts at lrdirect and they fit! So If anybody have the same problem like me, following parts are needed for 130 td5 back seats outer (bench): - BUCKLE RH BTR4372.C8 - BUCKLE LH BTR4373.C8 - HALF BELT BTR6561.C8 - HALF BELT BTR6562.C8 ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Good to hear you managed to sort it out. Kind of you to post the correct part numbers for anyone that might have to deal with the same confusion in the future... Defender 130 HCPU Td5 MY2000
